dzlndan's Avatar
Using 930 turbo top end on a 1991 3.6
I would like some help with knowing compatibility issues of using the top end components of a 930 turbo, and the long block of 1991 964, 3.6
I have a chance to pick up the long block from a car that was burnt. At a reasonable price.
I would like to put it in my 1982, 911
Here are the parts I have
930 components
complete intake manifold with accessories
CIS fuel distributor with lines and injectors
complete exhaust system
waste-gate
K27 turbo
oil scavenge pump
lambda computer with harness
diverter valve elbow
Bailey Motorsport diverter valve
Stock inter-cooler complete with piping.
Air-box
Any help would be greatly appreciated!
Old 12-03-2014, 02:26 PM
for starters the intake flanges are not compatible and at 11.3:1 the compression ratio is going to be way off
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 12-03-2014, 02:48 PM
Chain fence eating turbo
Head stud spacing alone kills the deal.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-03-2014, 06:21 PM
TurboKraft's Avatar
BTDT, and it's a long, tedious, and expensive process to do it all.
* 964 compression too high
* the 964 exhaust valves aren't sodium-filled
* intake ports are 3-bolt -- adapters needed
* exhaust ports are much larger than your exhaust
* no provision on 1-3 camshaft for scavenge pump
* the 930 CIS won't keep up all-stock
* fan shroud & ducting
* and then you'll still encounter all the usual late-engine-in-an-early-chassis issues: engine sheetmetal, p/s delete, crank pulley, A/C, engine oil cooler, throttle cable...
Honestly, easier to build your engine. You'll get a "new" engine instead of replacing a known used engine with an unknown used engine.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-04-2014, 11:26 AM
