Chain fence eating turbo
Besides money and perceived value loss, what is holding you back from EFI?
Want to hear if there's some myths out there to be dispelled.
When I owned lesser makes, I had to beef up EVERYTHING to make the engine, trans, and chassis take the power. A 930 (or a late G50 Carrera 3.2 in my case) needs virtually nothing to withstand great power, yet is stifled by CIS. Point is, we have the PERFECT platform/canvas to do what we please power wise, but a lot of folks retain the CIS. In all due respect, CIS was a marvel and still is, but EFI allows nothing but limitless power and great driving capabilities. So please help me understand. I love getting PM's/emails asking EFI questions for those wanting to convert BTW, helps me retain what I've learned. |
E-85 sippin drunk
With the addition of ethanol in our unleaded gas (and the possibilty of the percentages rising in the future), I would say that converting would be a wise choice. Yes, for the purists, and the very high valued limited number cars, keeping the CIS would be a good thing. If it were me, and I had one of those cars, I wouls still convert to EFI, and retain the factory CIS stuff (pickled) on a shelf.
After seeing first hand how much flexability EFI offers, not to mention drivability, I would not run the CIS.... Just my .02
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Crotchety Old Bastard
I can think of only one reason to go EFI and many reasons not to. The only way I would consider it is If you can perform the install and the tune yourself. If not you'd better have deep pockets and a lot of time. I hear so many nightmare stories. The worst, and this was a fellow I know personally, was after $30,000 three "expert" tuner shops and several years he still had a car that didn't fully function. He sold the car in frustration.
That did it for me. |
What are the reasons?
No computers/electronics/black boxes... leave it simple! |
I've decided that if i'm going to keep this car for any length of time it has to be converted to EFI. I think Rarlyl8 is right though, if you are not capable of doing it yourself its going to be a very expensive proposition. On the other hand, i'm pretty sure that i'll be able to get a very basic MS2 setup done for around $2k by doing the whole thing myself.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
If you research the CIS system you will realize that is is FAR from simple. An EFI system is extremely simple mechanically.
^^^ Very familiar with CIS and that's the main reason it stays in my car...
Converting to EFI will start messing with electronics and a new learning curve... If you want EFI get a car that came out of the box with it. |
beancounter
My 911 race car has motec EFI and ITBs. Amazing combination. If I put EFI on the 930, its going to be with ITBs, so yeah - its going to be expensive.
I would not hesitate to convert to EFI if my CIS were having issues, but its not. CIS parts are hard to come by and expensive. Faced with the cost of repairing a CIS set up, EFI conversion makes economic sense and nets better performance and driveability as a bonus. My CIS runs great. If it ain't broke, I'm not "fixing" it.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
By that logic, if you wanted a car with more than 300hp you should have bought one that came out of the box with it.
Having had cis and now efi I can see both sides of the coin. Cis if running correctly is pretty much reliable, I think cis becomes complicated when modifications are added without correctly choosing all of the components needed to run it safely. Efi can be pretty much a set it and forget it type of system but if one is not experienced and decides to do their own tune without much homework..one stroke of a key can give you headaches or worst.
Now with that said(and taking money out of the equation)..it's a decision I'm glad I did. If you have a stock car that runs really great then I would stick to cis. If you decide to go to efi then choosing the right components and tuner(if not doing it yourself) should yield you a set it and forget it system. Efi system can implement a lot of fail safe into your build that no cis can offer...plus your mpg's may go up...
Rey....77 930 "the Mistress" |
If I had the money I'd be tempted to install EFI and a Carrera manifold. A friend has done it and the throttle response is instant like a normally aspirated EFI motor. The horsepower is then only limited by the rest of the set up.
I also like classic old school cars and mechanical gadgets that will never be built again as long as they are in good condition and working correctly. My CIS is modified for more fuel flow and AFR adjustibility and that was around $1000 I spent on it 7-8 years ago so that increased it's value for me. I know it well and as long as it's working good and smooth during cold start and everywhere else it's OK. . . . but if I could afford to go all out and have Turbokraft design me a perfect working EFI conversion that I could install myself I'd probably do it and sell the CIS lump. |
$1500 EFI is a myth. Used parts or build-your-own like Megasquirt? I would think that way out of the realm of a typical experience. If not we are all ears.
1. MegaSquirt II - $444 (fully built using SMT components 2. Ford EDIS ignition complete - $100 used 3. Main EFI wiring harness (12ft) - $85 4. Ganged fuse block - $30 5. GM IAT sensor - $19 6. BMW TPS sensor and pigtail - $50 used 7. CHT sensor - free from Motronic setup 8. 6 EV-1 injector pigtails - $48 9. Going Super Fast crank trigger wheel, dizzy plug, and VR sensor - $200 10. Ford Focus VR sensor for crank trigger - $20 11. Crown Vic plug wires (Bosch) - $60 12. TunerStudio and MegaLogViewer - $70 13. Various wires and connectors - >$100 Off the top of my head, probably not leaving out much. |
^^^ that's exactly what I mean... and on and on and on... and sometimes it works, and sometimes it works great...
Good question, Tippy.
I'm curious to know, too.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
But my newest 80lb injectors were only $300 from Siemens. |
