930 rebuild
I am going to have to open up the motor on my 930 as I strongly suspect a bad bearing.
In contemplation of this large and expensive project I had a few questions.
What are my bearing choices for a 930 crank? IIRC I have ready several post where the bearings currently available are not what they used to be?
I was thinking about going to a 964 or GT3 crank should my 930 crank need work. Thoughts on that? IIRC the GT3 crank will need more clearance in the case.
How good is a crank repair of welding, turning back to correct size, and hardening?
The use for this car is street only with some spirited hill country roads in a 78 sunroof delete mostly stock Euro 930 (has SC cams and 993 heat exchangers).
Thank you in advance.
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 01-18-2015, 10:08 AM
You should also ask this question on the engine rebuild forum. There's some helpful people there that know what they are talking about.
Old 01-18-2015, 10:35 AM
Chain fence eating turbo
John, IIRC, a Carrera 3.2 is the same exact crank as the 930. This should open up the search for a good used one.
When I tore my 3.2 down, the journals were perfect after a hard life over 500hp. I almost reused the bearings they were so pristine.
Opposite of classic American iron where the journals show wear in a short timeframe.
Old 01-18-2015, 11:20 AM
beancounter
jwasbury's Avatar
A mentioned by Tippy, 930 shares a crank with 3.2 Carrera, so you can find STD/STD cranks. When I did my rebuild, the rod journals were marginal (under spec but above wear limit). I have the crank re hardened (nitriding process) which actually increased the dimension back to spec. This is documented on my rebuild thread (easy to find on this forum).
Best,
Jacob
Old 01-18-2015, 11:25 AM
3 restos WIP = psycho
kenikh's Avatar
It is the rod bearings that are crap, not the mains
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-18-2015, 12:32 PM
mussberger's Avatar
Quote from Mike Bavaro when he was rebuilding mine.
"Steve,*Crank is back, balanced and polished. It measures within .0005" of new!Remarkable, I take liquid coolers apart with half the horsepower and half the miles and they are worn almost to the limit!"
My rod bearings were smoked but the mains were fine.
They don't make stuff like this anymore.
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 01-18-2015, 01:53 PM
kenikh's Avatar
50% more main bearings than a V8 = no surprise
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-18-2015, 02:00 PM
Exactly!
Old 01-18-2015, 04:19 PM
I believe they are the same, but the distributor drive gear has to be changed out.
Yes, that's what I have read is the rod bearings are not as good as they used to be. They seem to wear quickly. I have read some turn the rod journal down, IIRC to a smaller size and use a GM bearing which would require a different rod, again IIRC.
Old 01-18-2015, 06:55 PM
At least you can reuse your dizzy gear then and swap between the 2.
Old 01-18-2015, 07:40 PM
