MikeD930's Avatar
Alan, thanks for the tip. I only needed to remove the gear clusters and not the shafts. I am waiting to get the gears (slightly re-hone to square up the bearing surface in case it's off from installing new synchro hubs) and flywheel (resurface) back from the machine shop. Then my gearbox will come together.
MikeD '87 930
Old 03-13-2015, 01:21 PM
Alan L's Avatar
You are doing a first rate job. Obviously have some experience in this area. Typical of many of the guys here. Keep up the good work. I always count 'dollars and cents' between each gearshift - even on the track - which is the only place I use the beast. I've had about 5 seasons out of the box since I rebuilt it, but 2nd is getting a bit grumpy now. I have to count 'more dollars and cents' for that shift.
I changed my ratios via Guard Transmission, if you are still looking for gears
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-13-2015, 01:50 PM
Non User
infraredcalvin's Avatar
Mike,
Sorry I never posted a response about the sir tool. Looks like you got around using them with the chisel, that probably worked better anyway.
For those using the sir tool to remove synchros, the ridge on the edge of the tool that fits into the synchro groove is shaped opposite than the way you need to use the tool. Hard to explain, but if you compare the tool and the synchro, the synchro has a triangle shaped groove that the tool fits into. If you align the tool with the groove so that the ridges match, then you have to push on the bottom of the tool to get the synchro off. The tool will break with too much force on the bottom. It is designed to push on the top, the more you push, the more it spreads the tool and helps release the synchro.
When I did mine I had no choice as the tool kept popping out of the groove due to the misshaped tool, I flipped the tool and got it loose enough to put a gear puller on it, but it destroyed the tool and the 1st gear synchro hub. After a couple months of Mr. Sir telling me it was my fault and I was doing it wrong (hard to tell if your doing it wrong if the damn thing doesn't come with any instructions) he finally gave me a replacement tool.
Oh yeah, BTW the tool is only supposed to be used with a hammer, not a press... WTF beating with a BFH is supposed to be easier on the tool than constant regulated pressure from a press? Design the tool correctly, and it would work soo much better....
Anyway, sorry for the rant, I thought I was over it...
Back to your post, great job so far. Keep it going! I'm hoping to tun my key tomorrow afternoon for the first time after a trans build, head stud and leak repair (almost a full top end rebuild)!
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 03-13-2015, 03:13 PM
MikeD930's Avatar
I did looked into SIR tools but decided to not to consider them due to reasons you mentioned. I figured if the tools were never redesigned properly then why buy them? I don't blame you for your rant and thanks for sharing your experience with the tools. I hope all went well with your repairs!
MikeD '87 930
Old 03-15-2015, 05:03 PM
Thanks for sharing this rebuild, so much great info here with very good photos.
I plan to tackle this job later in the summer so it's great to see that it can be done at home.
1987 930 Turbo - 3.4L EFI Conversion
Old 03-23-2015, 07:51 AM
Brando
quattrorunner's Avatar
I hesitate to state this but for posterity........
So I got my 930 gearbox disassembled partially and the shift forks were not together with their respective rods. So it was a little confusing. Anyway it doesn't work well if the fork is installed upside down. Just doesn't work.
I gut it all together and it's cool.
Turbo powa!
1977 911s. it's cool
Old 03-27-2015, 09:31 PM
Mike any progress?
Old 04-03-2015, 04:18 PM
MikeD930's Avatar
There has been little progress. It seems there's two step forward then one step back as usual with most folks involving with any project. In this case it has to do with several things. One involves 3rd gear (.93 gear) which I recently found out it's not acceptable due to pittings in several teeth. I did not noticed this when I received the gears last month until I cleaned it up getting ready for gearbox assembly earlier this week. So I'm waiting for a resolution with its seller who will get with me next week. Over the past several weeks I had the machine shop to repair 2nd gear (1.44 gear) (removed a dimple mentioned earlier) and lightly honed inside bore of 1st and 2nd gear. So far these two gears looks good. Second problem has to do with a bearing for input shaft between reverse and 1st gears. I noticed some groovings in several roller bearings so I ordered a special bearing from a bearing shop (Bearing Headquarters) which had to be shipped from a factory. I requested N305EN bearing but received N305E bearing. Note that suffix code "N" is missing...this specifies grooves on the outside of the outer race for ring clip. The bearing shop claimed they could not find it. I'll have to order from this host which I should have done in the first place. So these two problems are the major hold up on my progress.
Another potential problem I'm dealing with is a clutch disc I ordered from Clutchnet. Over two months ago I ordered a Kevlar disc...I received it after waiting 4 weeks. Turned out that the disc has organic on one side and kevlar on another. This is not what I wanted so I returned it to have a full kevlar disc. It is now 4 weeks and still have not received it yet.
Still another project I'm working on is replacing one CV joint in the rear axle (it developed notches in ball bearing races even though the axles are only 6 yrs old (10k miles) and repacking all CV joints. I'm not looking forward to it...messy...messy!!
MikeD '87 930
Old 04-04-2015, 05:45 AM
measure the disk from clutchnet. Porsche spec's the disk to be 10mm, with a max wear limit of 8.5. Both disks I received from Clutchnet were between 8 and 8.5. The new Sachs disk I just received was 10mm....
tim
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 04-17-2015, 06:15 PM
MikeD930's Avatar
tim,
My clutchnet disc also measured 8.5mm but was told it's fine to use. My old Sachs Kevlar disc measured 7.5mm which still worked fine until the diaphragm spring broke in the pressure plate.
So far my new clutch with rebuilt KEP PP is working great. I have not ran my car hard yet since the Kevlar clutch needs to be broken in. Clutchnet suggested 800 miles...no way I'm going to wait that long. So far I put in close to 100 miles (mostly around town...not highway). Still a way to go.
MikeD '87 930
Old 06-09-2015, 03:39 PM
MikeD930's Avatar
It's been a long 2 months...I returned a 3rd gear expecting an exchange. But no...the seller (Knightrace and YermanCars, both work together and I bought gears from both sellers) did not have the ratio I requested. Again more delay. But he did have Perfect Power's mechanic to inspect the gears which he said is fine and should last another 100k miles. So I agreed to use it. Meanwhile I replaced one CV joint and regreased three other CV joints. To be honest I wished I did not take apart the three CV joints! It's too messy and they did not need to be regreased but I supposed I wanted to torture myself learning how it's done. Having a press is necessary to remove and reinstall a CV joint on its axle shaft.
I also replaced an input shaft bearing (ordered from pelicaparts).
Now onto the gearbox assembly...below is an order of assembly sequence following a Porsche manual. Note that I used wording (pinion) and (input) to designate which shaft a gear is installed onto. "Pinion" is a shaft the drives a differential whereas an "input" is a shaft that goes to the clutch. Also, the shift forks will be adjusted after gears are assembled.
1. 4th gear (pinion)
2. Needle cage, spacer (input)
3. 4th gear (input)
4. Operating sleeve/slider for 3rd and 4th gears (input)
5. Slider with shift fork/shaft (input)
6. Bushing, spacer, needle cage (input)
7. 3rd gear (input)
8. Spacer, 3rd gear (pinion)
9. Thrust washer (input)
10. 2nd gear (input)
11. Bushing, needle cage for 2nd gear (pinion)
cont.
MikeD '87 930
Old 06-09-2015, 03:52 PM
MikeD930's Avatar
continuation...
12. 2nd gear (pinion)
1st Gear Input
13. 4. Operating sleeve/slider for 1st and 2nd gears (pinion)
14. Slider with shift fork/shaft (pinion). Note orientation of slider (assymetrical for 1st gear synchro versus symetrical for 2nd gear synchro)
15. Bushing, spacer, needle cage, 1st gear (pinion)
16. Thrust washer (pinion). Note orientation of washer
17. Spacer, 1st gear (input). Note that boss on 1st gear goes against spacer
cont.
MikeD '87 930
Old 06-09-2015, 04:00 PM
MikeD930's Avatar
continuation...
18. Roller bearing (input)...note that I temporary installed an old roller bearing which is a loose fit comparing to a new bearing that needed to be heated to install which I was not ready yet in case I need to take apart the gear sets again.
19. Roller bearing (pinion)
At this point I needed to adjust the shift forks so I installed reverse gears, lightly tighten nuts on ends of shafts and installed shift detents.
As expected the 3rd/4th gear fork is centered
1st/2nd gear fork is obviously off (too close to 1st gear synchro)
Before adjusting shift fork tape was added and marked. This shows the alignment of the fork on its shaft.
Then loosened and centered the fork
cont.
MikeD '87 930
Old 06-09-2015, 04:07 PM
MikeD930's Avatar
continuation...
I replaced the input roller bearing knowing the gearbox will come together.
Installed shift rod with its lever within selector forks
Applied gasket sealer to mating surfaces
Installed paper gasket
Install fork selector cover
Install reverse gears and torque shaft nuts. Use same technique to lock the gears as explained during removal process (shift gearbox to 4th gear and use reverse idler gear). Then install front cover using gasket sealer and paper gasket. Also install reverse gear detent. Sorry no photos.
Completed gearbox
Before the gearbox was closed up permantly I temporary installed center case, reverse gears/nuts, front cover and fork selector cover in order to check the shifting of all gears including reverse. I suggest to temporary hold the reverse gear detent/spring as shown below. That way you can get the feel of reverse, 1st/2nd and 3rd/4th gear shift pattern. Since everything is new it takes quite a force to shift into the gears except for reverse which has no synchro. Once everything shifts as expected then the gearbox is ready to be closed up.
Sometime later this week I'll write about clutch and installing the engine/trans. So far I have driven close to 100 miles and all checked good especially the shifting.
MikeD '87 930
Old 06-09-2015, 04:23 PM
MikeD930's Avatar
Before putting the clutch together I checked the new disc for runout/wobble. I placed the disc onto the shaft and spun it which checked good.
Installed clutch
Setting up to mate the gearbox to engine
Success after several attempts to engage the TOB
Engine ready to be installed
Rear of car jacked up higher then rolled engine into place
Then rear of car is lowered onto jack stands
Finally jacked up engine/gearbox while checking everything clears during this step. Engine is installed!
Finalized project. The action of the clutch is much smoother...not being grabby and shifting is firm and crisp. I'll call this trans rebuild a success once I hit 500 miles.
So for those who are on the fence to do the gearbox rebuild...do it! Normally it would not take this long to rebuild. I hit several road blocks due to exchanging clutch disc (wrong disc sent to me), rebuilding PP, returned defective 4th gear (different seller) and returned questionable 3rd gear that was supposedly acceptable and shipped back to me.
One important tip...if new synchro hubs were installed then plan on having the gears lightly honed if necessary by a machine shop to prevent potential bearing lockup.
MikeD '87 930
Old 06-11-2015, 06:08 PM
Banned
very nicely done, MikeD!!!
must feel great after such an accomplishment - good for you and excellent detailed descriptions / shots
car looks great - first stop: tires 8-)
SOooooooooooooooooo... nowwwwwwwwwwww you have noooooooooooooo excuse (no more short gearz!!!) to not HEAD EAST 7/23... jah?!?!?!??
Dooooooo eeeeeeeeeeeeeeeeeeeeet... and wrangle 'ole Cole into comin on out withyous!!! Either in caravan, or copilot - but - BE HERE!!! I talked w/ him yesterday and told him to heckle you about such... make us PROUD my friend!!!
Old 06-12-2015, 04:42 AM
MikeD930's Avatar
Hey Paul...thanks.
I already have family vacation plans to go west around that time.
Edit:
Family vacation is now sometime during month of Aug...so I'm free during July!!
MikeD '87 930
Old 06-12-2015, 12:54 PM
MikeD930's Avatar
Achtung...achtung! As noted above in the edited posting...I should be available so yeah Paul I'll make an effort to join up with you turbo bums at Jake's place...aber ja!
MikeD '87 930
Old 06-16-2015, 05:22 PM
Banned
^uberawesomeness^
Old 06-16-2015, 06:37 PM
MikeD930's Avatar
I almost forgot about this thread. It's been around 500 miles since the gearbox rebuild. Everything is still going smooth. It used to be easy to grind the synchros when shifting into 2nd gear but now always snicks into any gear. As for revised gearing there are pros and cons but in my case the pros outweighs the cons.
Pros: lower highway engine rpm (stock 4th gear), quieter highway cruising, reduced no. of shifting, longer pull in each gear.
Cons: more frequent wrong gearing (one gear too low and next gear too tall for a given speed), more noticeable turbo lag (I'm not implying that the turbo lag got worst...just that having an engine that reach full boost at 4k rpm is more noticeable using stock gearing than short gearing).
Overall...I'm glad I rebuilt the gearbox/clutch and revised the gearing. I hope this thread will be of help to those who will partake gearbox rebuild.
p.s. Paul...as mentioned elsewhere...sorry for not making it to the East side due to my daughter's car wreck. I was bummed and my daughter felt bad when she found out about my cancellation.
MikeD '87 930
Old 10-12-2015, 02:06 PM
