IMR-Merlin's Avatar
jarvis intake question
From some searching, I believe I have a Jarvis intake on my build.
Can anyone tell me where this goes?
Old 01-28-2015, 11:44 AM
Might be for the thick reinforced vacuum hose that goes down and connects to a metal tube that runs through the center tunnel and eventually hooks up to the deceleration vacuum operated brake booster on the master cylinder for your power brakes.
..how was that for a run on sentence.
Old 01-28-2015, 11:55 AM
IMR-Merlin's Avatar
perfect. I will have to figure that out. Does the booster have a storage canister and is there a one way valve to keep the system in vacuum while under boost?
Old 01-28-2015, 11:59 AM
The brake booster is the vacuum storage cannister along with the large vauum operated diaphram that's inside it.
The black and white plastic hose fitting that is pushed in to a rubber grommet on the brake booster housing is also the check valve that holds a vacuum inside.
Old 01-28-2015, 02:57 PM
IMR-Merlin's Avatar
Thanks, I am getting close, but still far away from running this beast. I just got my bulk ignition wires so that I can move my coil packs to where i want them
Old 01-28-2015, 03:30 PM
