Does it Matter
Got both suggested from our host. I had never seen the Porsche brand. Any opinions?
63 356 So Called Outlaw
76 930
Old 02-12-2015, 05:06 PM
Discseven's Avatar
LES... good question. We could start comparing specs to get to the answer. Filter I'm looking at...
Purolator L30260 = 97.5%* efficiency at 20 microns
*Based on ISO 4548-12 20 microns on L30001 --- looks like results are for different model filter. Could mean anything but at least there's something to reference.
What specs do you see for 2 filters you have?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 02-13-2015, 02:52 PM
Crotchety Old Bastard
RarlyL8's Avatar
Spec is only part of the importance, the OEM filters also have a bypass valve that allows oil to go around the filter should it become clogged. You can see the difference in your photo.
Old 02-13-2015, 03:43 PM
But the Mahle does not? What type filters do you run?
Jimmy Foster
78 911 SC
Old 02-13-2015, 04:52 PM
3 restos WIP = psycho
kenikh's Avatar
I always thought Mahle was OEM
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-13-2015, 10:58 PM
Mobil One makes good filter too.
Old 02-13-2015, 11:04 PM
RarlyL8's Avatar
I don't know which aftermarket filters have the spring valve, just brought it up as an important item. Good to ask when purchasing.
Old 02-14-2015, 06:47 AM
mark houghton's Avatar
I've been running with Mahle's all these years, only because I bought a case of them at a great bargain many moons ago. Unfortunately they perished in the carnage, or at least I think so since I can seem to locate them now.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-14-2015, 07:41 AM
MikeD930's Avatar
It's interesting to see that Porsche LS128 filter is made in USA. I have never seen it before...always used Mahle filters.
MikeD '87 930
Old 02-14-2015, 07:57 AM
Our host lists them both so I thought I'd compare. I've always used Mahle. I did try the Mobil 1 years ago when I was running Mobil1 after a rebuild.
76 930
Old 02-14-2015, 11:51 AM
geshaghi's Avatar
It looks like the Mahle filter has the bypass valve from the picture, no?
George E.
www.autoinno.com
www.AIRMotorSports.com
Old 02-14-2015, 01:12 PM
Yes it does.
76 930
Old 02-14-2015, 01:14 PM
Banned
I've always used (tminus zeroseconds for Ronnieism)... Mann (2n's!) filters in all my heaps.
Check valve?
Never looked.
German.
Old 02-14-2015, 01:20 PM
Banned
Originally Posted by krasuskyp View Post
I've always used (tminus zeroseconds for Ronnieism)... MEN
ALWAYS looking for more!
German, BUTTofcourse.
Fixed for accuracy!!!
Old 02-15-2015, 04:05 PM
