Need fuel mixture knowledge on 930 turbo ASAP!!
So I finally have my afr hooked up and the car is idling at 10.. so very rich if not richer. I have a fellow pelican here with a 964 who has experience with adjusting using the 3mm allen adjustment on the top of the fuel head. At this point we are not getting any feedback with any incremental turns. Even done larger full turns to lean it out with no success.
Have tried with pressing the adjustment thing down as well as not pressing it down always returning back to square 1 after not getting results.. Any tuning gurus out here to help now?? Thanks in advance.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Are you sure that you have a calibrated sensor?
and what's your timing at? If you are running too retarded (not full retarded, NEVER got full retarded) the fuel will not have a chance to burn and might give a false rich indicator.
So heres where I'm at. When I pressed the adjustment thing all the way down it wouldnt turn. So I removed the airbox as well as the housing for the adjuster.. I inserted the allen wrench as you can see in the picture but it feels seized.. should or could i spray pb blaster in there to get it to turn??
when you push the allen wrench down against the spring move it side to side -
there is a notch to engage when you engage the notch tiny movements make a big AFR change at idle and across the rpm range you must be seized , use some PB blaster like you said |
Tinkering Pays!!
you're missing something there: the adjustment sleeve which has the allen head on the top is missing???
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
Tinkering Pays!!
After a little research, I see that some CIS don't have the spring loaded screw [like mine].
Here's a pic of something like what I have:
Crotchety Old Bastard
The housing for the adjustment screw has been removed (post #4).
With the engine off, are you able to push down on the adjuster and see the air meter plate move (is it free)? What is the history of this engine? Has it not been running for some time?
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
![]() It doesn't move smoothly so letting it soak for the night before assembling everything back tomorrow. I bought the car off a fellow pelican earlier this year and it hadn't been started in about a year when I got it.. but got it running a couple months back but never did any fuel adjustments until now since I just installed the afr this past week.
Mine was very tight and took some teeth gritting to move it. Once it moves the rotation should be notchy.
I found too lean and too rich was less than a quarter of a turn apart. Have you tested some other cars to verify the gauge is working on various levels? |
I relate to the seized fuel mixture screw, I had to soak mine for a day before it would turn.
What is your CCP, WCP (cold & warm control pressure)? You should have CIS gages hooked up at this point. If the pressure is too low your afr could be in the 10-11 range.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
I think, as you have implied, that hooking up the gauges, and setting all the pressures to spec will give you a good starting point/baseline, then use your AFR gauge to fine tune. tim
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
Thanks for your help!
Hoping tomorrow I will be able to report back with good news on it
Has your WUR been modified to be easily adjustable?
My $0.02 - I would go messing with the idle adjuster just yet. It sounds like your WCP needs to be adjusted to raise cruise AFR which will also raise your idle AFR. After doing so your boost AFR will need to be richened up. The first things I would check before making AFR adjustments: - Make sure both fuel pumps are getting good voltage. - Make sure the WUR is getting voltage. - Make sure all vacuum lines are fresh. - Make sure your intake piping from air filter to throttle body doesn't have any leaks. |
Preferred pronoun:Maestro
Them thar be some seriously rich cruise numbers, Jacob, and getting lean on boost. Are you sure you don't have them reversed? I should be able to bring my CIS gauges over Friday evening when I'm back in town unless you no longer need them by then...
When in doubt, use overwhelming force. Last edited by nkowi; 07-06-2015 at 02:37 PM.. |
Banned
No doubt about that - much highway cruising with those numbers would have the back of the car so covered in unburnt-fuel/carbon splatter, that one would think that Paul had strafed it following a night spent binging on re-fried beans and tequila!!!
I'm sure I will still need them Friday Norm! I'll have it ready for whenever you have the time to swing by either Friday or the weekend.
