Speedometer issues
My speedometer works intermitantly mostly not work. This is a 79 930 turbo with an 87 motor. The sending unit on the transmission is white with two bullet connectors as connections. I do not know what the transmission year is but with this description hopefully it will be enough. I cannot even find one that looks like this.
Wish I was smart enough to post a picture but the ones in have seen. Have 5 contacts
1-purple/red hot
2- skip no terminal
3- white and red
4- 3 brown
5 - 1 brown
On mine there is no white and red
3- 3 brown
4- 1 brown
5- empty
Can some one tell me what the white and red is I cannot find one anywhere.
Old 07-13-2015, 04:42 PM
IMR-Merlin's Avatar
I think that is your reverse light switch. I have a G50 trans in my car, so I am not the perfect person to ask, but my speed sensor is in the differential cover.
One wire goes to ground, the other is your signal.
Test for ground and if that is good, you can then jump a wire from the signal wire to your speedo and drive it for a while to see if this is the issue.
Others might have a better option, but this will isolate
A) bad ground first
B)bad wire from sender to speedo
If neither of those work, then you have 2 other options. Sender and speedo...
Old 07-13-2015, 05:03 PM
Anyone got a picture of the speed sender location
Plus help with white/red wire on speedo
Old 07-13-2015, 05:26 PM
Alan L's Avatar
Above your throttle linkage lever where it connects on the trans case. A round unit about the size of your reverse light switch. Two fixed wires come out and join in the tunnel housing behind front seats.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-14-2015, 01:30 AM
Certified User
billjam's Avatar
I found a couple of photos that might help ...
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 07-14-2015, 06:47 AM
Alan L's Avatar
Whoops - I was wrong side of trans. Sorry.
Alan
Old 07-14-2015, 12:21 PM
