Is this a good mounting point for o2 wideband?
Hi guys
Is this a good mounting point for a o2 sensor for my wideband?
Cant seem to find a good place for it?
This is a BB exhaust single outlet
Old 07-30-2015, 07:16 AM
3 restos WIP = psycho
kenikh's Avatar
Hard to tell what you're pointing at, but the conventional location is just aft of the turbo outlet, at the 10 o'clock position.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-30-2015, 07:32 AM
16Volt's Avatar
AEM FailSafe Wideband Install Porsche 911 Turbo | Speed Academy
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 07-30-2015, 09:03 AM
16Volt's Avatar
Placement
Wideband O2 Sensor Placement on 930
Wideband AFR sensor location
Is this a bung for a wideband sensor?
WideBand O2 Sensor Placement?
Old 07-30-2015, 09:04 AM
Is there anywhere to put it on the pipe instead of on the can?
Old 08-01-2015, 12:36 PM
mark houghton's Avatar
Here's where I put mine on the old crispy critter.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-01-2015, 06:09 PM
Chain fence eating turbo
You want it after the turbo and before the muffler.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-01-2015, 07:50 PM
Ideally, yes, to prevent possible lean reading due to ambient air if installed post-muffler as mine was. Some discussion and concern has been voiced about the sensor withstanding the higher exhaust temps when installed pre-muffler, so I eventually chose the safer route (for sensor longevity). For what it's worth, I never had any issues.
Old 08-02-2015, 04:29 AM
There is so little room post muffler and I am so tired of removing muffler / bumper etc
Has anyone have experience with those probes that go in the tail pipe?
Old 08-02-2015, 04:33 AM
Too much latency IMO after the muffler. The gases stay "trapped" in the sound deadening areas since being diffused. I'd think it'd be hard to tune this way at part throttle. At full tilt, tuning shouldn't be that bad since the shear velocity of exhaust gases prevent stagnant accumulation.
Old 08-02-2015, 04:39 AM
Yep, at full tilt boogie not an issue due to the velocity of the exhaust. At idle, there's a chance that you'll read lean and end up adjusting richer than needed....but that's not bad vs. the alternative. I figured that most of us use AFR metering to be sure we're not too lean on the top of things, and this location works fine for that.
Old 08-02-2015, 10:34 AM
kenikh's Avatar
There's an issue is if you ever think you will use an EMS in the future. Then you want latency as low as possible.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-02-2015, 11:02 AM
Mark, there's just so much irony on you stating where to place the sensor to avoid "burning" it up. HEHE
Old 08-02-2015, 11:38 AM
Yeah, fer shur!!!! Though I have to admit that my sensor didn't survive the epic event. But still, life is good....
Old 08-03-2015, 04:38 AM
