-   -   Are we using the wrong spark plugs? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/879324-we-using-wrong-spark-plugs.html)
mark houghton 08-18-2015 05:28 PM
I've alternated between NGK B8ES or NGK racing (don't remember the number off the top of my noggin). Both are copper. That doesn't make me an expert any more than the rest of the commentators here....but it's what I use and I use what seems to work for me. Y'all are free to use what you want, but the science of heat transfer rates can't be disputed, unless you don't "do" science 'cause you failed it in high school and settled on a career as a librarian ;)
Das Schnell Ei 08-18-2015 05:58 PM
Originally Posted by Speedy Squirrel (Post 8757851)
Uh, no.
explain... " uh , no " gets nothing done SmileWavy
I have never heard of anyone recommend running platinum or iridium plugs in a forced induction engine that has been modified. I know you sure as hell don't do it with nitrous or a lot of boost..... whats the point? you going to put 100K on one of these cars without changing the plugs? "uh, no"
Speedy Squirrel 08-19-2015 09:20 AM
Originally Posted by kenikh (Post 8757732)
The thermal conductivity part is true.
The thermal conductivity data is true, but the meaning is beyond YouTube dude.
kenikh 08-19-2015 09:26 AM
I did the rounds talking to various individuals with practical knowledge in this area. All have had no issues with iridium plugs. Richard Clewett actually recommends NGK Iridiums for my Tec3r.
My guess on the video: Water cooled cars run WAY more boost than we do. 2 BAR isn't uncommon for a full tilt EVO with a big Garrett turbo. At that heat and pressure, thermal conductivity likely comes into play. At .8 - 1.2 BAR in a 930, not so much.
Speedy Squirrel 08-19-2015 09:27 AM
While pre-teen Tippy demonstrated the kind of scientific inquisitiveness that would guarantee him success in later life, his experimental technique was fatally flawed in this instance. As you bend the gaps open the electrode alignment (side to center) is messed up.
Originally Posted by Tippy (Post 8757734)
I did a science experiment in middle school on spark plugs.
What I found is Bosch Platinums gave off a much weaker spark than good old copper Autolites. I did other plug types in between. I did this by using my lawnmower and a rig to hold the gaps for the spark to jump. I simply moved each plug further away until no spark.
I know it was not totally controlled variable wise since me pulling the rope could have changed the magnetos strength, but I did it several times as an average.
It was a drastic difference.
Speedy Squirrel 08-19-2015 09:31 AM
The W3DPO is a platinum plug.
It is also a copper plug.
Oooooooooo!
Originally Posted by jsveb (Post 8758052)
Aren't the recommended W3DPO's platin?
kenikh 08-19-2015 09:33 AM
^ this is also what I discovered: Electrode, one material. Body, another.
Speedy Squirrel 08-19-2015 09:40 AM
Awesome. Love to provoke thought on this forum. Beats the heck out of reading about Zorks too!
krasuskyp 08-19-2015 01:36 PM
You seem to have this bizarre hang up against Zorks - how / where did Zorks so wrong you I wonder? :confused: (did one get 'shoved' inadvertently / advertently 'somewhere' somehow sometime???) Hmmm.
Yeah, because I've had soooo many people driving behind me exclaim about my spark plugs "WOW! That is EARGASMIC!!!".
Oh, wait... that's exactly what was exclamated by folks following me @ der recent turboPALOOZ'er... about... my... Zork.
Things that make ya go hmmm... SmileWavy
:D
Janusz1 08-19-2015 03:54 PM
After 2 solid pages I still do not know what plugs should I use on my standard modified 1978 (Kokeln IC, Kokeln turbo 3.4 P/C, 7.5 compression and BB headers).
Are W3DO0 good or not?
And, how often to change them driving aggressively on the street but no track?
Ronnie's.930 08-19-2015 04:19 PM
Just put a Zork on it and call it a day! :D
Oh, and be sure to post about it so Speedy Squirrel can have something good to read!
Tippy 08-19-2015 04:39 PM
I removed the ground electrode. I used solid wire as the ground, not the ground strap itself. Opened, measured, and noted.
mark houghton 08-19-2015 06:46 PM
Amen brother, we're having fun now on yet another thread of plugs. Hey, not to rank on a young kids scientific inquisitiveness that's now reached our "adult" scrutiny; I seem to recall doing similar experiments when I was young and stupid but seeking knowledge. Now, I'm old and stupid but still seeking. I think I'll stay with copper, tried and true. I don't give a rats ass about longer plug life at the risk of detonation. Plugs are cheap, rebuilds are not.
Ronnie's.930 08-19-2015 06:55 PM
. . . I did this by using my lawnmower and a rig to hold the gaps for the spark to jump. I simply moved each plug further away until no spark.
So Cory, did you touch the plug tips, and/or wire leads, to any errr, ummm body parts to see what it felt like (when the teacher wasn't looking)?!?!
Tippy 08-19-2015 07:18 PM
Ronnie, it was at home in the privacy of........er..........never mind
I never knew my pre-teen anecdotal experiment would get so much play...... :D
Speedy Squirrel 08-20-2015 07:11 AM
If you have the stock CD ignition and wires, W3DPO is for you.
This link to a previous post covers spark plugs in detail.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/837537-best-spark-plugs.html
Speedy Squirrel 08-20-2015 07:45 AM
All spark plugs have copper cores, and "copper plugs" actually have a Nickel plated center electrode.
The small center electrode of modern plugs run at the same temperature as previous plugs. They have the same heat ranges available. They present a smaller area to conduct heat into the electrode, and they have a smaller mass to cool down.
Actually, I think you would be hard pressed to cause pre-ignition with a spark plug in a 930. The exhaust valve is going to get you first when you push things out to the edge. Search on the late JBL930's posts for the worst pre-ignition I have ever seen in a 930.
One last though, a vehicle I helped develop
Is the Alfa 4C, 21.8 psi boost, 1.7L, 237HP, running NGK R 0.4mm center electrode.
Speedy Squirrel 08-20-2015 07:49 AM
It's all good. I just wanted to yank your chain and see how many emoticons and bold font vowels you would cough up!
:D
DSPTurtle 08-20-2015 08:57 AM
Funny story... was pulling apart a blown up Boxster motor yesterday to start a rebuild and it had three Autolites and three Champions in it. People will use anything!!! :( These aren't Ford's or lawnmowers... one day people will understand. HaHa
kenikh 08-20-2015 09:53 AM
^ That is some Space Coast engine-uity!
