-   -   Are we using the wrong spark plugs? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/879324-we-using-wrong-spark-plugs.html)
klefroid 08-17-2015 10:57 AM
I think I just bought the wrong spark plugs? :D
https://www.youtube.com/watch?v=dgFVN9iMnLg
heliolps2 08-17-2015 06:53 PM
Yes sir
Hams930T 08-17-2015 07:08 PM
Thanks for sharing. I will freely admit I have typically run Denso Iridium plugs in my cars. Clearly I need to rethink that approach.
smurfbus 08-17-2015 09:57 PM
Switch/ E85, done.. I hate changing sparkplugs so I will stick to platiniums for durability. But if problems arise need to rethink this.
T77911S 08-18-2015 05:37 AM
platinums dont always work best. i went from a bosch platinum to a cheap copper in my truck. it not only ran better but gas mileage went up alomst 5mpg.
use either copper or the bosch CS (silver).
Speedy Squirrel 08-18-2015 06:47 AM
Seriously!? You are going to switch the plugs in your $100K cars based on YouTube dude?
LMAO
kenikh 08-18-2015 07:56 AM
The thermal conductivity part is true.
Tippy 08-18-2015 07:59 AM
I did a science experiment in middle school on spark plugs.
What I found is Bosch Platinums gave off a much weaker spark than good old copper Autolites. I did other plug types in between. I did this by using my lawnmower and a rig to hold the gaps for the spark to jump. I simply moved each plug further away until no spark.
I know it was not totally controlled variable wise since me pulling the rope could have changed the magnetos strength, but I did it several times as an average.
It was a drastic difference.
Tippy 08-18-2015 08:00 AM
LMAO
They are tuners by trade......not exactly a rookie IMO.
Das Schnell Ei 08-18-2015 08:01 AM
Has this not been known for a while?
boosted/ nitrous should use normal plugs
Speedy Squirrel 08-18-2015 09:09 AM
Uh, no.
Tippy 08-18-2015 10:42 AM
Originally Posted by Speedy Squirrel (Post 8757851)
Uh, no.
So we should be using Iridium and Platinum?
jsveb 08-18-2015 11:05 AM
Aren't the recommended W3DPO's platin?
kenikh 08-18-2015 12:28 PM
My mechanic buddy uses NGK BR9IX - iridium - plugs in 930s. Waiting great back if he's noticed anything, at least in hindsight, in regard to different plug types.
WinRice 08-18-2015 12:38 PM
You need Splitfire's or E3's, a quart of Slick 50, and a cool collar, then you're good to go!...............;)
On a more serious note, here's a good read:
http://www.ngksparkplugs.com/docs/tech/Racing_Spark_Plugs_Performance_Applications.pdf
kenikh 08-18-2015 12:39 PM
Slick 50! It's Teflonated!
WinRice 08-18-2015 12:42 PM
You betcha!
And if it's Teflon, it's got to be good for anything!..........;)
speednme1 08-18-2015 12:56 PM
Interesting...back around 98 when I had my 3.2 I switched to platinum plugs. Car ran like crap. My mechanic at that time had me switch back to copper. Car ran great plus the copper ones were a lot cheaper.
Tippy 08-18-2015 03:50 PM
HAHA, what was that stuff that they took the oil pan off the car and sprayed water on the crank as the engine ran?
That'd top it off!
Tippy 08-18-2015 03:51 PM
Wonder how much of that had to do with not being resistor plugs? For sure the spark would be weaker.
