Backup light does not work
Hi,
Was trouble shooting my backup light last night. (1979 930) Backup switch work fine on transmission. From what I can see, pin 5 & 6 is used on the 14 pin connector, where 5 comes from fuse box and 6 goes to backup light. I measures no current on pin 5, so I guess it is some place between 14 pin connector and fuse box. From what I can see from diagram, it should be a green/yellow cable. Could not find this color going to the fuse box. Also tried to make a jumper cable from another pin that had current to pin 5, just to test, but even then the light did not work. I tested the connection between pin 6 and the tail light backup light. there was connection. Any suggestions?
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Have you pulled bulbs and checked for power there? Sometimes the obvious is overlooked. Ask me how I know! Happy turkey day
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Yes I did. No power.
Measured the connectivity from the bulb + side to pin 6 on 14 pin connector. was good
Thread Tools | |
Rate This Thread | |
