Chain fence eating turbo
Drag radials are drag slicks with grooves to pass DOT. Even at 100PSI, the sidewalls will be squirmy.
Lucky you didn't lose control complately! They are squirmy with front engine cars!
Old 12-13-2015, 04:40 PM
Crotchety Old Bastard
RarlyL8's Avatar
The two extremely different kinds of tires are definitely the cause!!
Possibly, but not yet proven. The fronts stick, there is no understeer. I used to have oversteer and now that is gone. Others on this site run drag radials and I am hoping they chime in. I know tire types can be vastly different in characteristics which seems logical, however I have not had this problem in the past and have run mismatched tire types front/rear many times as the sizes I need are not available in all makes.
I don't think these drag radials are slicks with grooves, they are sticky street tires with a street tread pattern which can be seen in the picture. The pattern is nearly identical to the front tires which is why I chose them. I would think cheater slicks would have a much more simple tread design.
I have no issue getting rid of these tires if they are the problem but I sure don't want to buy something else and still have the same problem. I don't deem them unsafe, they just feel funny.
Old 12-13-2015, 06:03 PM
I have run drag radials, they are made to have soft sidewalls to absorb torque and flatten the contact patch. Hence, "wrinkle wall".
They were never intended for a corner, I assure
you.
Your car will never handle well with those NT555R's. A'int gonna happen
Old 12-13-2015, 06:15 PM
When I posted about using different front and rear tires - even though from the same manufacturer/brand/ rating - people posted that it was likely to cause a wipeout at anything over 5mph .
Old 12-13-2015, 06:19 PM
RarlyL8's Avatar
They are not wrinkle wall, that would be ridiculous on a road handling car. The wall height is 4.3" and the tire is stretched on a 12.5" rim. The 345/35-15's I had on previous to these had 4.75" wall height, more wall flex, and puckered on the 12" rim.
I'm going to guess from all the info given that the squirmy feel is due to the tires not letting go but having a thick soft tread that is moving side to side as I traverse the corners. The sidewall is not flexing, but rather the tread itself.
Old 12-13-2015, 06:56 PM
Does sound like tread block squirm. Shaving the tire wound reduce tread depth and decrease the tires slip angle. Or just put more miles on them until settled in.
Old 12-13-2015, 07:08 PM
Alan L's Avatar
With a very soft compound on tread blocks the car can feel like it is driving on blocks of butter ie squirmy. I have not had this experience in a car, but driving karts on wet tyres (very soft compound) on dry track has the feeling you describe. They don't let go - the compound has plenty of bite - but the chassis rolls around a lot. A less rigid feel than on a harder compound. Less feedback in terms of connection with the asphalt. Not my cup of tea. If you had same up front I think you would find it quite disconcerting.
Regards
Alan
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-13-2015, 09:24 PM
RarlyL8's Avatar
That is EXACTLY what I am trying to describe!
It looks like everyone is correct in one way or another. These tires have upset the handling, how much of it is the compound and how much is the front/rear ride height bias is not determined.
I guess I need to look for a different type of tire. When I bought these I did not know they were drag radials - a friend of mine told me that when he saw them on the car (he uses the exact same tires on his 1000hp Corvette). His car is never driven hard in a corner so he had no info for me on the problem I was having, all he said was "you ain't gonna break THOSE loose".
SO, what tire do you guys recommend?
Old 12-14-2015, 04:47 AM
I think the Toyo R888 tires will work well for you. Make sure to mount them on the front AND rear!
If you want something less sticky, more affordable, more comfortable and still an all around high performance tire I also suggest Bridgestone Potenza RE760 Sport.
Old 12-14-2015, 05:32 AM
I have enjoyed;
Nitto NT-01's - on the 930
Toyo R1R's - on the 86, 3.2 .... I don't they offer sizes for your set up
Potenza RE760's - on the 89 Euro M5
I didn't much like the R888's which I tried on an 88 M6 then took off and gave to a buddy.
If it was me Brian, I would put on a set of NT-01's.
Good grip and predictable at the limit,
Dave
Old 12-14-2015, 06:44 AM
I have enjoyed;
Other guys like the R888's I just couldn't get them to work for me.
Dave
Old 12-14-2015, 06:45 AM
wayner's Avatar
1) Mismatched tire baloney?
Some tire combinations work well together others not so much. It certainly is one variable, but not the definitively cause without further investigation. I hate when people preach that tires of different makes or models will send you off into the weeds as if turing the key becomes an ejection button. A matched set of known quantity will eliminate this variable, but will it resolve the handling concerns or has it more to do with the new tire size?
There are certainly some combinations that are less than ideal, and especially at the limit, but others that work well. You have to become your own tire engineer and analyze it. Playing with tire pressures or having a second set to try and experiment are a cople of ways of diagnosing.
Having said that, while waiting for my new front tires to arrive, I drove 300 miles on street rears and R compound fronts. For liability reasons I am certianly not recommending it, but after many twisty roads, when I got to my destination I did a few vigorous parade laps (certainly nowhere near the limit but spirited none the less). That has to be the absolute worst combination on a 911, but I was fine at reasonable speeds.
2) Tire squirm
I'd run them for a while just to put some miles an heat into them.
The 4 yokahama S drives that I put on my wife's miata were really weird handling with not much traction until we had about 200 miles on them. Why?
-Heat cycles to finish curing the rubber?
-Mold releas compound to wear off?
-too tall tread blocks?
Who knows but they sorted themselves out after a few miles and became excellent tires.
3) Suspension?
If this is your first set of super wide rear tires on a 911 they will feel much different due to the offset and affect on geometry. They will also put more force on your suspension. On the race track with 4 matched tires, my car fells like on turn in there won't be much traction, but then they take a set and rail through the corner. There is always a lot more than I expect once the car sets on its suspension. I have 30 rear torsion bars, and my adjustable rear bar set to mid setting. My racing buddy says my car is not evil but feels like it could use a bit more rear. It really seems to want to squat on the outside rear corner with these big boots.
4) Tire diameter
Another guarantee to send you into the weeds (or not)?
Back in the day some of the race teams ran bigger rears to get more tread on the ground, skirting the tire rules that limited width. (Contact patch can be increased by diameter or width). It does introduce another variable of weight bias though.
These variables all likely have an effect but not one of them is definitely the cause. What else was changed at the same time? the tire brand/model/traction/ width/diameter/other?
SOLD - 914 wide body hot rod
Old 12-14-2015, 06:50 AM
I can tell that from a lot of responses, folks have not run drag radials.
I don't care what pressure you run nor how long you break them in, they will not handle as well as a dedicated handling tire. The sidewalls and tread is designed to flex to absorb torque and widen the footprint under load.
Crikes....
Old 12-14-2015, 07:00 AM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by Craig 930 RS View Post
Holy crap man, your tires could not be more different front to rear! Definitely the cause
^^^ THIS ^^^
I've learned this lesson, as well. I'll never mix and match tires again.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-14-2015, 07:49 AM
wayner's Avatar
Crikes....
Yes, but is that the only change?
I'd hate to see him buy more tires and still not be happy with the result.
P.S. Kenik
NEVER mix and match? Always a disaster?
...or just recognize that it is an untested combination and some tires may not work together as well as others?
Old 12-14-2015, 07:53 AM
There's a 3rd element, the tire compound. Drag radials only need a light hazing to get sticky. They're not like road racing tires that take awhile to heat up. You spin them, they're sticky. You roast them, they turn into gum and become greasy.
Old 12-14-2015, 07:58 AM
Alan L's Avatar
Brian,
I've got 'mismatched' tyres on my track car. After lots of experimentation I have ended up with Nitto 01s (255) on the front and Kumho V700 (275) on the rear. The Kumho is a soft tyre with high tread wear factor. This is the best balance and handling the car has had. It has swapped the oversteer for a slight under steer at the limit (which is my preference). I don't know how the Nittos will go in the wet (They say for dry only).
Regards
Alan
Old 12-14-2015, 10:31 AM
Me like track days
Craig 930 RS's Avatar
Guys, the thing here is the F&R tires of the OP'er are RADICALLY different...
Not all that dissimilar to a snow tire on front and a Z rated street tire on the back. Just a bad combination, bad idea, etc ... sorry...
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-14-2015, 10:37 AM
Agree and disagree. You can throw the complimentary front tires that Nitto recommends for the rears, and it will still be crappy in handling.
It's a friggin' drag radial!
Old 12-14-2015, 10:55 AM
Me like track days
Yeah I wouldn't run a Nitto streeter on a HP 930 either. And totally different F&R tire construction is just insane in corners.
But then again I'm a dip**** who runs Kumho V710 track tires on the street because they feel sooo good. NO RAIN, lol.
Old 12-14-2015, 10:59 AM
