kostya.lyt's Avatar
83 930 - New Toy!
I've recently acquired an '83 930 and it's having some popping/clicking noise under acceleration. What could cause this? I've found some missing sealing rings on the pressure pipe (both sides - turbo and intercooler), the pressure pipe was easily turning and moving up and down 1/2".
Any thoughts?
Thanks!
'64 Beetle
'84 911 Targa
'83 930
Old 08-08-2014, 02:01 PM
Banned
Man, very difficult to say without more specific details of the sound and when you hear it (could be many things).
Clicking is usually associated with the diverter valve (metal piston in it smacking against the end caps when the seals there have deteriorated and turned to powder), that sound is usually heard when the throttle is suddenly closed (like when blipping the throttle at a standstill). But the sound made by compression loss due to broken headstuds could be described as clicking/popping and that would be heard under acceleration.
Is there any way that you can describe the sound, and conditions when it happens, in a more specific way?
Old 08-08-2014, 02:13 PM
jsveb's Avatar
Detonation, or pre-ignition?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 08-08-2014, 02:39 PM
It could be a broken head stud, similar symptoms. Pull rocker covers and check rocker shafts and, while your at it, check those head studs.
Old 08-08-2014, 04:31 PM
oilonly's Avatar
Well you will have to get that fixed first and then take it back out for a drive.
Just a guess here on what it might be by chance if not your loose charge pipe.
Bye Bye Clicking Sound..A Slow'N'Rusty Pictorial - BOV Housing
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 08-08-2014, 06:14 PM
kostya.lyt's Avatar
Well, this evening I replaced all of the o-rings and seals on the pressure side, it was missing both of the "seals" that go on charge pipe. It certainly helped the idle considerably, it is much smoother and quieter now.
The bad part is that the popping is still there under acceleration. It doesn't sound like a high-pitched exhaust leak, but a more "substantial" and lower tone exhaust pop. It doesn't pop when slowly building the RPMs to about 3,000 or so, but it does pop at low RPMs with more of a load and under acceleration.
'64 Beetle
'84 911 Targa
'83 930
Old 08-11-2014, 07:49 PM
Forced Induction Junkie
WERK I's Avatar
More than likely a backfire. It's a lower tone because of the long path back (throttle body, IC, turbo, plumbing) to the fuel metering plate. Does it happen only when the engine is cold or all the time?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 08-12-2014, 04:54 AM
kostya.lyt's Avatar
All the time, although it seems to get a bit worse when it's warmed up.
'64 Beetle
'84 911 Targa
'83 930
Old 08-12-2014, 05:34 AM
Head studs?
Old 08-12-2014, 05:43 AM
totle's Avatar
Think Oilonly nailed it.
Check the gaskets in the blow off valve.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 08-12-2014, 06:29 AM
kostya.lyt's Avatar
Would this cause a significant backfire?
'64 Beetle
'84 911 Targa
'83 930
Old 08-12-2014, 06:43 AM
Banned
no, the shuttle valve end seals merely create an audible 'click / clack' when you snap-lift off throttle - you're hearing this UNDER ACCEL, not let-off...
you're either really lean, or your timing is off, or both
go thru the diag basics - need timing light for timing and CIS gauges for mixture...
...but, you can start by turning the air meter hex plunger bolt atop the fuel distributor to try to dial in small incremental amounts of fuel (turn Right for Rich / Left for Lean) and re-try
good luck
Old 08-12-2014, 06:56 AM
wjfk32's Avatar
Pull your plugs out--check/clean or replace
Chk afrs
Chk ignition-coils-box-wires--etc..etc..
Chk Hoses-lines-vacuum
Also-sounds you are running on 5 cylinders or/missing or detonation--not building boost. Similar situation happened in the passed with me. I would clean the plugs. Run well for awhile, then crap again. Changed all injectors-put an msf6al&coil-epoxy..plugs..cleaned distributor-fuel filter-fuel pumps etc..etc.... I did go extreme-but age/parts is a reliability factor. All worked out in the end.
Old 08-12-2014, 07:05 AM
Banned
oh, yeah good point - I had wicked popping (misfiring) when my distributor cap got scuzzy...
a vid would help us see what it's really doing, shouldn't be hard to shoot / post one...
Old 08-12-2014, 07:52 AM
kostya.lyt's Avatar
This evening, I pulled the wastegate to be sure everything inside of it was OK, as well as check the seals on the Air Bypass Valve, they were fine. Like some of the responses above, it is looking like some sort of FI or ignition issue (all ignition components replaced less than 100 miles ago). Also, I found the smaller of the two vacuum tubes going to the distributor completely broken near the distributor, this was fixed today as well.
A few questions:
- Can the air cleaner assembly be easily removed without removing too much around it?
- What kind of seal goes between the throttle body and the large cast piece (pardon my ignorance) that the intercooler seals to?
Wastegate...
What should this tube be connected to? It's almost like a "collector" running from fittings coming out of the bottom of the head.
What is this unit? How should the hoses be connected? Currently, one of them is just plugged.
'64 Beetle
'84 911 Targa
'83 930
Old 08-12-2014, 09:18 PM
oilonly's Avatar
That used to go to your smog pump. I would say make sure it is plugged as exhaust will be coming through there if not.
Old 08-13-2014, 05:19 AM
I hate to say it but head studs?
Old 08-13-2014, 05:21 AM
Banned
Yes - a bit difficult to remove some of the bolts due to limited space but can be done.
The large cast piece is usually called the secondary intake manifold and/or the diverter valve housing - it seals to the throttle body via the following orange, silicone o'ring (several brand options to choose from).
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
In picture #3 above - it was originally connected to the air injection pump which is drive by the left cam (pump is on the left side, directly behind the driver's seat) - emissions related device meant to increase exhaust temperature - many people, myself included, remove this system altogether.
Old 08-13-2014, 08:13 AM
kostya.lyt's Avatar
Here's a quick video I took a few minutes ago. Even blipping the throttle at idle makes a popping sound, not near as much when slowly building revs.
Porsche 930 Misfire - YouTube
'64 Beetle
'84 911 Targa
'83 930
Old 08-14-2014, 03:26 PM
DSPTurtle's Avatar
Check the seals on the recirc valve before you get too worried.
Old 08-14-2014, 04:36 PM
