LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
TurboKraft's Avatar
Thank you, gentlemen! Glad you found it helpful.
Originally Posted by bpu699 View Post
It was also neat to see Loctite 574 used on the case halves. And, this is the video where it looks like the ARP rod studs were torqued to spec not stretched...
Any updates? Any oil leaks or is the 457 adequate?
Awesome video series, thanks for doing it!
Yes, we used 574 on the case halves and the case webbing.
The ARP fasteners are so consistent that you can use torque in place of stretch on the rod bolts. Every time we've cross-checked torque and stretch, they have been right in range.
Last updates is the car is running fine up in the Toronto area.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 09-18-2017, 10:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
The ARP fasteners are so consistent that you can use torque in place of stretch on teh rod bolts. Every time we've cross-checked torque and stretch, they have been right in range.
Chris, it's great to hear a builder say they use the torque method... I suspect 90% of people do. When you send your rods for resizing, I doubt the machine shop does length measurements...
I know the 574 is supposed to cure only in anaerobic conditions... But when I took my original case apart, there was rock hard glue internally along the seem lines internally in some spots. I can only assume thAt was Porsche original 574. Ever seen that? I assume 574 under quarts of oil is technically, anaerobic...
Great videos...
Old 09-18-2017, 07:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
TurboKraft's Avatar
Correct -- the factory used 574 and when submerged in oil it is in an anaerobic environment and cures.
The only reason we can do torque-only on a rod bolt is because it is ARP and highly consistent. We've never had one end up out of tolerance when checking stretch. We also have the Snap-On torque wrenches calibrated periodically.
Our machine shop does check the rods' center-to-center lengths for consistency, and verifies both ends are honed completely parallel prior to balancing.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-19-2017, 09:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
If you use a lot of 574, do you risk it hardening inside in clumps and breaking off? I always imagined the 574 dissolved in oil, so it didn't clump. Seeing it hardened in the cAse along the seam suggests it could break off and clog galleys. That said, it was stuck on really hard and needed a razor blade to scrape it off...
Old 09-19-2017, 11:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
Ken911's Avatar
Yes I found a little of it in my oil pump strainer screen. The next time i was more carefull and had no sqeeze out.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 09-19-2017, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
TurboKraft's Avatar
It would have to be very small to make it through the oil pump's strainer.
From there it would be sucked up by the scavenge side of the pump, then off to the thermostat and possibly get lodged in the front oil cooler, otherwise back to the oil tank's filter.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-19-2017, 11:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
This is awesome.!
Great to see the progress.!
Cool step by step pictures.!
Scott D Anderson
88 930 Turbo
74 914 LE Bumble Bee
Old 09-23-2017, 11:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
