16Volt's Avatar
BOVs/MAP/LEASK RPM Swich Signal Source
Hey, I saw some of you are running a dual diverter setup, I will be doing the same.
I plan on running a standard 710N style Forge valve vented to atmosphere on the intake elbow (fabspeed bypass hose). I then have a different Forge valve plumbed into a shortened mid-manifold (slidevalve section removed). This is also vented to atmosphere.
I am new to running two valves so please forgive my ignorance here.
That being said, where are you pulling signal from for both of your valves? Do you run a single line and T it or grab two separate ports on the throttle body? I no longer have a decel valve btw.
I feel like one set of ports off the throttle body pull from above the butterfly and one set after.
Thank you for any help you can provide.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 04-07-2016, 02:07 PM
Banned
Shannon, this does not answer your question(s), butt I don't think a BOV vented to atmosphere works very well with CIS/K-Jetronic - doesn't that cause an extremely "false rich" condition by making the air metering arm move much father downward than is actually required at sudden closed throttle(a huge air leak, in other words)? Or maybe I'm mistaken about that?
Old 04-07-2016, 02:17 PM
16Volt's Avatar
Well upon closing you will get a burst of richness - hence the flames on lift. There really isnt any harm though (to my knowledge). The issues most people relate to venting to atmosphere is cars using a MAP/MAF for mixture control in the ECU. Those car's electronics are expecting to see that air volume re-circulated.
Venting to atmosphere in CIS does not fundamentally change where your air metering arm is to my knowledge. I vented to atmosphere on a CIS-E system (arguably more advanced than the Porsche plain old CIS) and there was no issue.
Old 04-07-2016, 03:55 PM
16Volt's Avatar
Bumping this thread - I want to finish all the vacuum wireing this weekend.
So...anyone? Even if you aren't running a dual setup, where are you pulling signal from? Im considering plugging the port in the intake (965 style) tube and just running the unit after the intercooler and before the TB.
Because people love pics....
IMG_1351.jpg by Shannon, on Flickr
Old 05-23-2016, 12:05 PM
I can't help with your question but your motor sure looks sweet. Nice to see that Fabspeed hose blacked out. What product did you use ?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 05-25-2016, 09:21 AM
3 restos WIP = psycho
kenikh's Avatar
'lektrikl tayp
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-25-2016, 11:43 PM
jsveb's Avatar
Originally Posted by kenikh View Post
'lektrikl tayp
Yes, for this application it certainly beats Jaybee Waeld
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 05-26-2016, 07:11 AM
16Volt's Avatar
Once again...I am surprised by the lack of actual information in this forum.
Old 05-30-2016, 10:45 PM
16Volt's Avatar
Self bonding silicone tape. Goes by the name 'emergency tape' or 'helicopter wrap'. Good for pretty much everything, it will patch a coolant hose in a heart beat.
On amazon its 'x-treme tape'.
Old 05-30-2016, 10:50 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
So you're asking where to hook the vacuum signal hose for the aftermarket BOV(s), correct?
If so, any place after the throttle plate (otherwise, no vacuum to operate the BOV). If it were mine, I would use the nipple (such a great word right thar!) on the throttle body that used to supply the vac signal for the vacuum limiter (decel valve), and then a "t" to supply a vacuum signal to both BOVs.
I guess we have different ideas of what constitutes "information", as I have learned more about 911s & 911 Turbos on the Pelican forums than anywhere else by far (also get to enjoy a lot of laughs while doing so).
Old 05-30-2016, 11:19 PM
Banned
Um, wut?
Yeah... ummmmmmmm, no.
(says the guy consciously running a 710N lol)
Aren't you an Audiot???
Ps. I didn't know Rawknees' nickname was "Port"?
Old 05-31-2016, 04:09 PM
Banned
pps.
Intarestin technique @ attempting to garner assistance, to boot?
Old 05-31-2016, 04:36 PM
Any port in a storm, bub!
Old 05-31-2016, 07:38 PM
Me like track days
Craig 930 RS's Avatar
This forum is like Jr. High, mixed with a dollop of community college, with a tad of debate class and philosophy class ............ mixed with great information, lol
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-02-2016, 11:07 AM
930T Owner
Hams930T's Avatar
You can run it off one port off the TB and "T" the line. That's not a problem.
- Chris.
Hams930T
2017 Turbo S
Old 06-03-2016, 12:27 AM
