Suggestion for replacement drop links? (with rant)
I have **** Weltmeister rear drop links in now with a Weltmeister stiffer rear sway bar.
I'm tired of screwing with them.
The thread stripped on the eccentric bolt one from normal street use!
Paragon sent me a replacement which I promptly stripped during install because the morons used an IMPERIAL thread on a part for a METRIC car!!!
WHAT KIND OF DROOLING MORON DOES THAT?
And I guess the (supposedly 7/16" thread) was close enough to M12 to fool me, but not enough thread engaged to not strip.
Then Paragon sent me an incorrect replacement replacement. I decided to check the thread on it. It is no thread size known to man. Another $50 into the trash.
Even though their installation document calls it 7/16" its not 7/16" x14 or x20. Its definitely 20 TPI though. And its definitely not M12 either! It might be M12.2x20 TPI.
Anyway, I want to keep the stiffer sway bar, and put the stock eccentric bolts back in, and use drop links that are well designed.
Who makes a decent product that will work? Suggestions?
Old 04-16-2016, 01:47 PM
Alan L's Avatar
Which bit are you talking about? I have no eccentric bolt on my drop links off the sway bar. Just a couple of thru bolts - tieing each end of the drop link in. One to the sway bar, one to the suspension arm from memory.
Alan
Edit; I am no where near my car right now. But I think my memory is coming back. When I fitted Elephant rear camber adjust I deleted the eccentric bolt for a thru bolt.
You could try Elephant Racing. Most of my rear suspension stuff came from them. No issues and totally helpful.
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-16-2016, 06:39 PM
I don't know what the Weltmiester ones are like. I have Tarret adjustable rear drop links and like them.
Porsche 911 Rear Droplink Set, 65-89 with 78-89 factory Swaybar
Old 04-16-2016, 07:07 PM
Administrator
Luccia at Pelican Parts's Avatar
Always been a fan of Tarret drop links. We have them here: Porsche 911 Tarett Engineering Adjustable Drop Link Set
Old 04-18-2016, 11:50 AM
