| Registered Join Date: Apr 2007 Location: wisconsin
				Engine longevity with 1 bar VS 0.8 bar spring?
			So, how much life are you shaving off a motor by increasing to a 1 bar spring? Assume proper afr/increased IC... stock motor. Clearly the turbo has to spin faster... Motor/pistons/valves/bearings/studs under greater pressure... clutch under greater strain... But what about the motor itself? Can you still get 100,000 miles out of it? 50,000? 99% of the time you arent driving at high boost... what kind of longevity are you guys with modified motors running 1.5 bar getting? | ||
|  04-21-2016, 07:02 AM |
| 3 restos WIP = psycho Join Date: Feb 2005 Location: North of Exit 17
			You need a baseline configuration.  Stock engine?  3LDZ turbo?  Early US exhaust, Euro exhaust, aftermarket? 1 BAR on a bone stock motor is not a great idea, as the backpressure from the stock exhaust and the 3LDZ turbo just aren't a good fit. Heat is your enemy and the previously mentioned issues, as well as stock timing and a crap intercooler compound the issue. That said, a properly modified engine can last every bit as long (or longer) at 1 BAR as a stock engine at .8 BAR.
				__________________ - 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 | ||
|  04-21-2016, 07:22 AM |
				 | Quote:
 Motor had 3% or less leakdown on all cylinders at 60,000 miles. The PO said it was rebuilt (lots of evidence to suggest thats true, but no reciepts), motor very solid... | ||
|  04-21-2016, 07:46 AM |
| Mighty Meatlocker Turbo Join Date: Apr 2016 Location: North TexASS
			It's difficult to say to what extent engine life is shortened by using a 1 bar spring, but two things to consider are an increased risk of detonation (the effective compression ratio is raised quite a bit and good a/f ratio does not guarantee no detonation), and increased cylinder head heat (comes with the territory of increased compression), which will obviously reduce the life of the valve guides, etc., and further raise the risk of detonation.
|  04-21-2016, 08:12 AM |
| Crotchety Old Bastard |
			Most 930 engines don't or didn't last anywhere near 100K miles, that is more typical of a 911 engines life. Several reasons such as lack of maintenance, bad treatment, adding larger boost springs (with no other changes), and poor fuel curve. If you take care of the engine and add an intercooler to offset the added 0.2bar boost it will do OK. Change out the exhaust to fee flowing, tune the fuel curve and there is no reason why the engine shouldn't last 100K.
				__________________ RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 | ||
|  04-21-2016, 02:16 PM |
				 | Quote:
|  04-21-2016, 02:24 PM |
