Chain fence eating turbo
Awesome! I know the feeling being down for a long time.
Old 07-02-2016, 03:51 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Always layin' the bait, Cory - ya' fookin' instigatin' instigator!!!
Old 07-02-2016, 04:30 PM
Originally Posted by JFairman View Post
One of the 3mm allen adjusters was turned clockwise or tightened all the way and that proves it. The other 5 adjusters were not turned clockwise all the way. They were close but not all the way because they were adjusted to flow the same as the one that was tightened all the way.
Jim,
I'm curious if the port adjuster that was tightened all the way in was port #4?
If so --- after you rebuilt the fuel head is port #4 still the limiting port that all the other ports need to be adjusted to match (giving the most flow but yet still balanced)?
Thanks for the info!
Old 07-15-2016, 04:31 AM
Metal Guru
911nut's Avatar
Originally Posted by RarlyL8 View Post
The way I understand it Porsche had a bunch of 3.3T CIS 930 engines when the 965 was stillborn in the late 80's (partially due to price overrun). They used the engines they had through 1994 in the 964T saving a ton of money. The Carrera went on in '84 with Motronic/EFI and then the 964 in '89.
What I've read was that Porsche was in tremendous financial trouble in '89 mostly due to antiquated product design and assembly methods. They are a small company and didn't have the manpower or budget to develop the 965 3.6 EFI Turbo engine alongside the n/a 964 engine they were developing to launch the new car.
The 930 was the company's cash cow ($40-50k premium for not a lot of extra content) but was going out of production with the other accordion-bumpered cars. The 930 engine could still meet the U.S. emissions standards almost as-is so they went ahead and developed the 965 for minimum cost, as a way to bring much-needed capital into the company.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 07-15-2016, 05:55 AM
Originally Posted by Kaefer View Post
Jim,
No it wasn't #4, it was one of the other 3mm spring tension adjuster that was tightened all the way. Then the rest of them were between 1/2 turn to almost tightened all the way to match the one that was tightened all the way.
Old 07-15-2016, 07:06 AM
Hi - I'm about to rebuild (more like repair) the FD on my 964 3.6T. I seem to have amateur houred it using carb cleaner to get plunger unstuck and melted an o-ring or something inside FD. Can't get combustion in cylinder #5 - spark has been checked. Either getting too much fuel or none.
I've read 100 pages on the topic today, and the one thing I am concerned about is making sure I can get even flow at all air levels when done. Can one adjust flow with it all back together using the under-the-cap-on-top adjustment screws? Or is part of the calibration meant to be completely internally?
73 911s Targa / 94 964 Turbo 3.6 / 77 Guzzi Le Mans / 93 Guzzi 1000s / 73 Guzzi V7sport / 77 Yamaha DT400 / 06 Ducati Paul Smart / 15 MBZ G550 / 01 Range Rover 4.6
Old 11-07-2018, 02:58 PM
Alan L's Avatar
You take the injectors out and place them to collect in small jars - like 100-150ml. Hook the lines back on, switch the pumps on and depress the airplate - anywhere you want - 1/2 to WOT. Collect about 50-70ml of fuel and measure each jar. That will tell you where your FD is at regarding #5 (and all others).
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-07-2018, 05:07 PM
Get a rebuild kit for it and do it.
The aluminum fuel heads are relatively easy. A bench vice to hold it while taking it apart and tightening it's bolts when it goes back together is needed. Wash laquer thinner is easy to find and works good for cleaning.
Old 11-07-2018, 05:08 PM
With stiff lines not easy to put injectors close by in small jars, needs not to twist the stiff lines.
Old 11-09-2018, 01:29 AM
Bucketlist's Avatar
Pick up 6 small plastic baby bottles - works for me!
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 11-09-2018, 03:23 AM
Old 11-09-2018, 05:34 AM
Alan L's Avatar
It is no problem, easy done. Ping the plastic retainer clips off to let the lines flex a bit, plenty of movement available. Done it dozens of times - different fuel heads/rebuilt heads etc.
Alan
Old 11-09-2018, 10:54 PM
