Tug68's Avatar
Need new Alternator
So car died on the way home last night, alternator crapped out. Should I put in rebuilt or new? Bosch or genuine Porsche? Also should I upgrade to larger amperage? Thanks in advance.
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 08-31-2016, 07:35 AM
I bought a higher amperage one off ebay last year from bnrparts Porsche 911 Alternator 1984 - 1989 High Amp 160 Amp High Output Generator. Unfortunately the link no longer works but a search will likely find it. It has worked well for a year at least.
Old 08-31-2016, 08:07 AM
Jeff NJ's Avatar
I found a guy in Chatham NJ that rebuilds them. Old School Italian with piles of these things in his shop. Got it done in a day for far less than you can buy one. ($150 or so??)
JC Starter & Alternator in Chatham if you want to google his contact info and take a drive down there. Probably an hour drive.
If you have a crazy stereo, or some other need for more amps, JFairman has recommended one in the past with additional capacity.
1988 930 Venetian Blue
Old 08-31-2016, 08:10 AM
Tug68's Avatar
I went with the one JFairman had recommended. For the price and the additional amperage you can't go wrong.
Tim
Old 08-31-2016, 12:59 PM
mark houghton's Avatar
How do you know that it's the alternator that crapped out? Possibly (and hopefully) more likely just the voltage regulator.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-31-2016, 06:26 PM
It is a most excellent alternator... nothing else even comes close.
Frank "xbmwguy" found it on ebay and when he got one I wanted one too.
If headlights are on and you have extra AC condensor fans running and killer stereo with lots of bass happening you need this alternator. It always shows a healthy charge happening... even at idle with all the stuff running.
They are built on Valeo 90 amp alternator frames and the guts, wiring, and voltage regulator are all bigger, better, and new.
http://www.ebay.com/itm/Porsche-911-Alternator-1984-1989-High-Amp-160-Amp-High-Output-Generator-/351776822932?hash=item51e7885694
Old 08-31-2016, 08:28 PM
jbrown's Avatar
I did same thing a month ago. Great product and good company
Old 09-01-2016, 05:39 AM
