What oil temp sensor do you use for EFI?
When I first installed mine that came with Bitzracing's kit, it looks like a thermocoupler that is installed onto the engine block, but I think there gotta be a better (more accurate) solution that can, for example, measure oil temp?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Oops... meant to say Engine or Coolant temp sensor in the title
Chain fence eating turbo
If you do warmup enrichment from oil, you'll be pig rich for a long time as oil lags head temp greatly
Good point... so you use CHT type sensor as well?
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Oil temp is nearly useless an engine temperature input to an EFI system. Convert to cylinder head temperature, enjoy having a single warm-up cycle.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Exactly!
When I was 1st learning to tune, I saw head temp went 300+ degrees on a 100+ degree day. I thought my warmup slope had to stop there! It was running in warmup mode forever making tuning painful until I learned OEM stopped around 150? |
