3 restos WIP = psycho
Running divided turbo on stock (open) flange?
Is there any downside divided turbo on stock (open) flange? The reasoning being one can run the divided turbo on a factory exhaust until one can afford to fabricate a divided exhaust to suit.
Sent from my Nexus 6P using Tapatalk
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Chain fence eating turbo
I did it. Honestly, when I finally divided the header, it didn't make a lot of difference.
But, I did make the divider about 3/8" tick instead of the 1/4" of the turbine housing possibly choking a little and causing turbulence. It's on my list of things to address while I have the motor down. |
No problems. Now, if you ran the full 24 hrs of Le mans you may have heat checking/erosion at the flange surface.
Thanks guys!
My 930 is set up that way using divided turbo with custom headers that are not divided. It was already that way when I bought this car. I don't know why whoever did this mod did not divide the headers. Anyway the divided housing will be fine as mine were good shape when I removed the turbo to add new compressor seal.
MikeD '87 930 |
Crotchety Old Bastard
If you were going to leave it that way (divided turbo only) I would file the turbo plenum to a sharp edge to improve flow. When you get your split plenum headers (all of ours are split by the way) you should match the dividers so flow is smooth. Every little bit helps.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Metal Guru
I'm in the opposite situation; I added the divider to my collector to stop the backflow and improve boost onset but I don't have a twin scroll turbo. I did gain a small improvement in boost onset.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
So with a twin scroll equal length primaries are supposed to help a lot. Does the Secondary need to be equal length also? Or is the fact that they are divided enough?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Everything should be equal length. There's some debate that you can essentially get the same effect in unequal exhausts by timing the length of one set of headers to be in phase, but one cycle off, but the maths hurt my head.
Everything needs to be equal length for a divided plenum to be optimized. Each pulse needs to hit the turbine at the same unique time and sequence as the exhaust valves open. The complexity to do this in an unequal system based on individual tube length would not only be a mathematical challenge but a packaging nightmare. Any compromise would ruin the effect. Our headers are equal length both on the primaries and secondaries with a divided plenum. Each bank gets a smooth transition bend waste gate outlet. The result is a minimum of back fill when using a single waste gate and open plenum turbo such as the K27. The tuned sound is completely different than short tube systems, off boost torque is greater, turbo lag is essentially the same as the short tube systems and HP is greater once on boost. All of this is enhanced further when using twin waste gates and a twin scroll turbo. Very quick response, big off-boost torque and big HP capacity. Tubing sizing can be kept conservative as well which enhances velocity for quick response without reducing power capacity at full boost redline.
