Bland
Carrera and Turbo Badges - how are they held on?
I want to put my Carrera and Turbo badges on my 76 back in the right order. How are these held onto the deck Lid?
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Of the Moby Gang
Just google-searched "Porsche Turbo Carrera" then clicked on "images" and will attempt to attach a link to one of the many photos found below:
http://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwionNezouvUAhUBy2MKHWG_A2cQjRwIBw&url=http%3A%2F%2Fdirectorblue.blogspot.com%2F2010% 2F02%2Fporsche-930-most-refined-use-of.html&psig=AFQjCNEg_Fst-KP8VshgwJOB9TNx1VoDFQ&ust=1499107909953923 Are there pin-studs on back side of your emblems to insert thru holes on your engine lid ? If your engine lid holes were filled and painted over, you will still find there exact location by looking on the inside of the engine lid. And then, what I have done is (using my hand ONLY, for precision, and not an actual drill) is to use the smallest drill tap I own which is either 1/16th inch or one size below that and spinning it carefully in the CENTER of each of the lid's thru-hole FROM THE INSIDE OF THE LID TOWARD THE OUTSIDE as a pilot-hole. Then working up to the size drill tap equal to the pin-stud diameter, by hand-spinning taps from the outside through your pilot holes. SPIN DRILL TAPS SLOWLY SO AS NOT TO CHIP OUT PAINT SURROUNDING EACH HOLE. And then, of course, installing the push-grommets or "speed-nuts" onto each pin-stud once each emblem badge is inserted into its lid holes. IF there are no pin-studs on the badges then it is possible that the Turbo-Carrera's emblems were attached with an adhesive double-sided sticky tape originally, and then you'd have a different procedure to do. This would involve using an appropriate adhesive out of a tube now that the original stickiness of your emblems is no longer sticky. And one of the challenges here would be to squeeze a not-too-big a stripe of the glue onto the entire backside of each emblem along the letters and placing it in onto the engine lid at a spot you'll have to measure and draw on to the lid first. If you have to glue it on, use a wax crayon (Crayola) or a "Wipe-Away/Easy-Erase-Board" marker to draw a rectangular right in the location on the lid that the emblem should be placed onto. Layout the two emblems flat on a table properly spaced apart as they'd be on the lid and measure the width of that area. Then measure the height of the emblems for the height of the rectangle your going to draw onto the lid. Measure the width of the engine lid. Draw your rectangle into the center of the lid's width BUT AT A HEIGHT YOU WILL HAVE TO DETERMINE from the bottom edge of the lid, or from the bottom edge of the rear-spoiler - because, the photo in the link seems to show the Turbo Carrera emblems closer to the lid's bottom edge than the line along the bottom of the rear spoiler making it appear that the emblem was not centered in that height column but affixed closer toward the lid's bottom edge. Hope I've helped get you started Last edited by Schwarzhorse; 07-02-2017 at 11:27 AM.. |
Access to the emblems is on the inner side of the engine lid/rear spoiler. You' ll have to partially remove the inner shield/liner of the engine lid. To do so, you'll need to remove the rear wiper parts, remove the very small screws carefully and slid the liner against the a/c hoses. This should give you sufficient access to the speed nuts on the emblems.
Good time replace with new "turbo" Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI "carrera" Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
1983 911SC 1974 914 2018 GTS 2019 Audi S4 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) Last edited by stevie 77 930; 07-02-2017 at 01:58 PM.. |
Pelican screwed up and sent me a double order (oh dont worry, they charged me for it and wont accept the return), but I have a black 'Turbo' badge if you need it.
I took the sealing gunk out the new speed nuts and replaced it with dum-dum before putting on my new badge. The sealing gunk that comes with the nuts dries hard as a rock while the dum-dum doesnt but seals all the same. Why did I do this? Because the two year old badge I put on promptly snapped both of the studs when I went to remove it because of the new speed nut sealing gunk.
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor Last edited by 16Volt; 07-03-2017 at 08:25 AM.. |
78-88 "Turbo" badges are different than 75-77
the correct the part # 93055931701 for early Turbos Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI ![]()
1983 911SC 1974 914 2018 GTS 2019 Audi S4 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Wrong forum, same topic. Does anybody know how the 2.7 is affixed to the engine grille?
The one I bought from Pelican for the rear deck lid is plastic (like $94 worth) and has two prongs which I do not believe are threaded.
My decklid is newly painted and does not have holes to accommodate the prongs. I'd like to glue it on with a double stick tape. Any recommendations out there? I'm pretty sure I just hijacked this thread big time. |
Porsche used the Carrera script on '76-77 U.S. Turbo Carreras and the RoW Turbo badge was a little too large so they made a special Turbo badge for North America. The Turbo badge material was a little different than the Carrera badge which is why they fade differently over time.
Thread Tools | |
Rate This Thread | |
