LinkBack Thread Tools Rating: Thread Rating: 1 votes, 2.00 average.
Robert Sanchez's Avatar
Porsche Crest missing at high RPM's
I have recently completed a clutch kit replacement at home on my 911 3.2 1984. It all looks good until I tested at high RPM ( more than 5000 rpm's) I find that it is missing only when it gets to 5000rpm's and higher. I checked the spark plugs for correct gap, I took the valve covers off and checked the engine studs to see if any were loose or fractured, I checked fuel presure because I replaced the filter, I checked the compresion and it's OK. Do you have an advice on what may be causing the missing at high rpm's?
Bob
Old 02-23-2003, 06:16 AM
Irrationally exuberant
ChrisBennet's Avatar
Bad plug wires can have that effect. Have you checked them in the dark for the telltale light show?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-24-2003, 07:44 AM
Smile
Thanks for your advice, I will try that tonight and let you know.
Old 02-24-2003, 09:03 AM
Unhappy
Noppp, no sparks at night. Still have not figued out the problem. CAN ANY BODY PLEASE GIVE ME MORE IDEAS!!!
THANKS
Old 02-26-2003, 01:54 PM
al lkosmal's Avatar
Hi,
I had the same symptoms with my 77S. My coil went out shortly afterwards. Replaced it and the problem went away. Do you have another coil to try??
Al
Old 03-02-2003, 12:23 PM
