Sigurd's Avatar
JB Racing dizzy and CDI
Has anyone used the JP Racing twin spark distributor with two 3-pin CDI boxes?
I assume I can connect 12V to + wire, orange, and split the dizzy out, purple, to the points inputs, C, on the CDI units.
Comments?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 08-29-2018, 08:19 AM
Jonny H's Avatar
It depends on the pickup type. As you appear to only have two wires from the distributor, my guess would be it has a VR (variable reluctor) pickup.
Unfortunately this is not compatible with a 3 pin CDI box. You either need to use 6 pin CDI units or change the pickup type to one that is compatible with a points type signal.
Firstly, ask JB to confirm the pickup type.
www.classicretrofit.com
Old 08-29-2018, 02:36 PM
Sigurd's Avatar
Johnny, thank you for your input.
From the JB documentation:
The distributor has two internal magnetic pickups
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 08-30-2018, 08:24 AM
ROW '78 911 Targa
timmy2's Avatar
With magnetic pickups you will need to go to 2 Bosch 6 pin CDI’s or a pair of MSD CDI’s.
MSD Streetfires are the least expensive route.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-31-2018, 04:58 PM
Sigurd's Avatar
Thank you. I have two 6-pin CDIs on the shelf somewhere.
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 09-01-2018, 12:36 AM
