Well, work continues on my complete bottom up engine rebuild on the 1988 911 3.2 Carrera Cab.
Here's a pick of the new axle boot rebuild, new shocks, clutch slave and hard line. Keep finding little things to tidy up as we go on my new to me 155k two owner CA Cab. Clutch Slave/satellite was weeping and hose bubble added to little things as we get closer to install of new engine. Hold up now is SuperTec head studs on back order. I'm told we should have them this week. After inventory of parts we believe this is the last of the parts to complete the top end. Stay tuned.
PCA, POC & SCCA long time Member Last edited by 996AE; 01-23-2019 at 09:06 AM.. |
Huge shout out to *************** a u t o haus AZ (pelican deleted full name.
Great prices on Porsche OE and OEM parts and service is outstanding. If they dont have it ive been using Sonnen. Both have been outstanding to work with. I am told my Supertec head studs are on the truck and scheduled to be delivered today! Pictures of top end assembly to follow.
PCA, POC & SCCA long time Member |
Engine P&Cs and reworked heads back on, valves adjusted ready for final assembly.
Pictures to follow.
PCA, POC & SCCA long time Member Last edited by 996AE; 01-24-2019 at 01:27 PM.. |
Plan is to fire her up tomorrow.
Waiting on injectors and flywheel resurface today.
iNSTALL TODAY
![]() Well the 4-6 week top engine build turned into a 4 month full refresh of my 155k mi 1988 3.2 Carrera. Bottom end opened up (why not were this far) so off we went. Polished and balanced crank, rebuilt oil pump, new bearings, gears and chains, reseal, new P&Cs, supertec head studs, rod bolts, etc... etc... Heads reworked, the list goes on. Valve guide leaks and failed smog caused the rebuild. Car ran great, just wouldnt pass CA SMOG. So down the supply slope I went. While you're in there parts list add to the fun. New rear shocks, rebuilt axles, filters, hoses, caps and rotors.... Of course powder coated tins, covers, pulleys.... so much fun.... Heading over to Sleepers this morning to hear the first start of my engine. Video to follow. UPDATE Engine in but fuel injectors not. Waiting....
PCA, POC & SCCA long time Member Last edited by 996AE; 01-28-2019 at 01:16 PM.. Reason: no start |
P U Car tomorrow. Test drive done by shop.
First thing tomorrow morning will drive from Costa Mesa Sleepers Speed Shop to Westend to visit with Darin and Chris for corner balance and alignment. Excited to drive her again after the 4 month 20k refresh. Video to follow.
Congratulations and looking forward to hearing how it felt to drive it after 4 months and a rebuild.
'71 914-6 #0372 '17 Macan GTS |
60 miles today. This after SSS did the inital break-in.
Ran through the break in routine. Smooth, quite, super nice throttle response. No real feel for power at 4k tops for a 100 miles or so. Lots of compression braking and no freeway cruising. Passed smog with flying colors today with the Magnaflow weld in CArb CAT. At 500 miles break in oil out, value check, test pipe and Steve Wong chip. As long as SSS approves of course. Francis is a solid engine builder and a great guy. 1988 911 has to be one of the best daily drivers out there. I factory spec'd and ordered a 1988 911 Carrera back in the day, and took European delivery 30 years ago. It was a coupe and this is a cab. Nice to add this to my small, but growing fleet of P cars. Westend (Darin) couldnt get me in until next week. Corner balance, four wheel alignment and new front inserts will complete suspension refresh. In less Darin finds something I havent seen. Ride height is currently set at 25 1/2 all four corners. Going to go Euro spec after new front strut cartridge installed.
PCA, POC & SCCA long time Member Last edited by 996AE; 02-02-2019 at 07:13 PM.. |
Just finished a long day of garage therapy.
SoCal rainy day so it was garage time. Several Porsche events around town, first Saturday kinda things but didnt feel like getting wet. So, spent the day pulling all the 30 year old carpet out of the car and steam cleaning and reinstalling. Amazing what a little deep carpet cleaning can do to a 30 year old car. I was going to post a picture but it wouldnt do it any justice.
Finally home
Well, rain stopped and this morning added some break in miles. Over 120 now. Only issue is a hanging idle. Drops nicely to 1100 and sometimes wont idle down, other times blip and she settles down to 970.
I'll have SSS check it out at the 500 mi valve check and oil change. Westend Gardena CA (Darin) confirmed alignment, corner balance and and Euro ride height is a go for tomorrow.
Back from WestEnd Alignment.
Darin went over the car and did his usual fantastic job. Drives like it should now. Next upgrade is turbo tie rods. New rear shocks and front inserts done along with sway bar bushings, Euro ride height and street alignment. Cant say enough about the PS2s on this car. Amazing combination when done right. 250 miles now on break in. Still under 4600 RPM. 5k according to SSS engine builder but I am still working my way up the RPM ladder.
PCA, POC & SCCA long time Member Last edited by 996AE; 02-07-2019 at 03:32 PM.. |
Rain has kept the fresh 88 Cab in the garage this week so no new miles added. This morning is dry and sun is out so she will get a little more time.
Picked up new Beru spark plug wires, test pipe and SS sport muffler to go with Steve Wong chip. SSS said to wait for 500 mile valve check, oil change break in miles before adding free flowing exhaust mods and chip. Stay tuned.
350 miles and car is running like it should. 4600 RPM tops so far, warm ups and cool downs with lots of compression braking.
After oil change and valve check I will find out how she really runs.
That's a lot of break-in miles! You've far more patient than most. Glad she's running well.
No physical quantity completely explains its own existence |
Yes, its killing me.
But my 12 mo 12k mile warranty from engine builder requires this approach. Next week she goes in for AC check up and estimate to get it working again. Hopefully not a big bill.
A run to Sierra Madre Collection open house and back hit 499 on the clock. Tuesday she goes in for her 500 mi valve check, oil change and overall check up.
Car is running great. For a few that have asked here is the breakdown on my new to me 155k mi CA car I bought for 20k knowing it needed a top end. Two prior owners clean car fax, service and books and records. Description total Paid x PPI 300 x Purchase car too much x Rear shocks/Sachs 194 x Front shock inserts/Sachs 194 x Cam oil line left 29.88 x Cam oil line right 30.85 x Brake pads - rear 26.68 x Rear rotors 83 x Sway Bar bracket - rear 87.25 x Engine rear gas lines (3) - Mesa hose 193 x Engine deck lid - replace Whale Tail 300 x Engine deck lid grill 150 x Engine deck lid paint 300 x Cat muffler bracket 14 x Axle Boot kit - 4 32 x Fuel cap 8 x Engine complete rebuild "Sleepers Speed" 13,259 x Air box clips 21 x Seats Leather recover 1450 x Steve Wong Chip 540 Viper Alarm 200 x Alignment, Euro ride height, inserts inst. 330 x Tires Michelin PS2 AS 498 x Delvac 75W90 gear oil DIY 58 x Airfilter Mahle 12 x Lloyds mats 60 x Cam chains (2) and sprockets (4) 400 x CAT delete pipe 166 x Muffler and CAT gaskets (4) + nuts/bolts 36 x MAHLE P&Cs US Spec 3.2 3,080 x Paint correction and ding repairs 500 x MAGNAFLOW CAT CARB compliant 150 x MAHLE fuel filter, BERU Cap and rotor 56 x Mesa Hose AC line 96.5 x Mesa Hose clutch to Slave line 49.5 x Clutch slave cylinder 74.5 x Beru Spark Plug wires 225 All in to date; 23204.16 Not including cost to acquire car, tax and fees of course. Last few items needing attention AC and Cruise control.
PCA, POC & SCCA long time Member Last edited by 996AE; 03-06-2019 at 10:24 AM.. |
Well, add 720.00 to the build cost. I learned today thats my cost for mandatory post build valve check and oil.filter service. SSS does give a 12mo 12k mi engine warranty so I guess its all good.
P U car with fresh oil, valve check and green light to find red line.
Steve Wong chip, test pipe and sport muffler next. Cruise control working, although I cant see ever using it. Motul oil is Sleepers Speed Shop oil of choice for my new 3.2 engine. Plan is to roll up to Banff CA this summer in my Carrera. Well, maybe cruise will come in handy on this run....
PCA, POC & SCCA long time Member Last edited by 996AE; 03-06-2019 at 10:23 AM.. |
