Nikasil cylinder cleaning / honing / red scotch brite
I can’t read anymore. Hours and pages and keep coming back to red scotch brite pad.
My cylinders have 97k, still have perfect cross hatching. I took them up to a professional to see and he said no reason to do anything but some wd40 on a red scotch brite and run it up and down twisting it a few times. I’ll be using JE pistons and rings if this makes a difference |
Did you measure them for out of round and taper?
Make sure you clean the cylinders till a clean rag comes out without any residue on it. I usually wash them with hot water and dawn dish soap. Scotch brite is an abrasive and you don't want any of it hanging around. Last edited by nocarrier; 01-31-2019 at 04:30 AM.. |
Also,
Are you installing brand new pistons in old bores that haven't been replated and sized to the pistions? Have you checked the clearance? |
What kind of build is this? If it's gonna just be a mild mannered driver, then by all means clean up and reuse. I have done so many times.
If, however, it's going to be a hot motor, I will either replate using millennium or US Chrome, or replace the cylinders altogether. |
Schleprock
Hatching is pretty visible but you can see the darkness indicates the ring material deposited. I would recommend the scotchbrite, super hot water (use long cuff thick rubber gloves) and dish soap like Dawn.
I know you said you read a lot. Hopefully you found this one. It was pretty good because Henry went above and beyond to prove his point. do I need to hone this? And you can't measure the bore with a set of calipers. Not even with a set of snap gauges (the things that expand and then you measure them with a micrometer) can you get it close enough. You need a solid quality bore gauge kit with a 0.0001" resolution dial indicator. Fowler makes a nice one but their dial indicator is only good to 0.0005" and that's not good enough when you're shooting for a gnat's arse crack sized clearance of 0.0015" between the piston skirt and bore.
Kevin L '86 Carrera "Larry" |
Chain fence eating turbo
Ditto KTL.
Capilers were not even allowed for measuring any F15 engine I did. |
Under the radar
I used a home made hone with red scotch brite pads. I ran each for about 30 seconds with my electric drill in a dawn solution. I carefully measured each of them before starting. This method works.
Did your machinist use a bore gauge or mic to check your cylinders?
abit off center
And a good set of gage blocks or master setting ring to set the bore gage Sent from my iPad using Tapatalk
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
As a machine shop owner, I can tell you definitively that calipers measuring a bore like that are a no-no.
Just not accurate enough. Also, here is PLENTY of scuffing on that cylinder. If it was me, I'd be sending them off to Millennium to get re-nikasiled and finish bored. Will cost you 1K. They will come back perfect. You don't want to redo this later. |
Attaboy!
