Nikasil cylinder cleaning / honing / red scotch brite
I can’t read anymore. Hours and pages and keep coming back to red scotch brite pad.
My cylinders have 97k, still have perfect cross hatching. I took them up to a professional to see and he said no reason to do anything but some wd40 on a red scotch brite and run it up and down twisting it a few times.
I’ll be using JE pistons and rings if this makes a difference
Old 01-30-2019, 10:25 PM
Did you measure them for out of round and taper?
Make sure you clean the cylinders till a clean rag comes out without any residue on it.
I usually wash them with hot water and dawn dish soap.
Scotch brite is an abrasive and you don't want any of it hanging around.
Old 01-31-2019, 04:26 AM
Also,
Are you installing brand new pistons in old bores that haven't been replated and sized to the pistions?
Have you checked the clearance?
Old 01-31-2019, 04:33 AM
What kind of build is this? If it's gonna just be a mild mannered driver, then by all means clean up and reuse. I have done so many times.
If, however, it's going to be a hot motor, I will either replate using millennium or US Chrome, or replace the cylinders altogether.
Old 01-31-2019, 06:42 AM
Put them in soapy water and just very lightly scrub, you can also get scotchbrite round balls that go on a drill. As others said measure everythin out first. If all is good I see no reason to replate or buy new unless you have no budget.
Old 01-31-2019, 11:05 AM
Old 01-31-2019, 01:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Hatching is pretty visible but you can see the darkness indicates the ring material deposited. I would recommend the scotchbrite, super hot water (use long cuff thick rubber gloves) and dish soap like Dawn.
I know you said you read a lot. Hopefully you found this one. It was pretty good because Henry went above and beyond to prove his point.
do I need to hone this?
And you can't measure the bore with a set of calipers. Not even with a set of snap gauges (the things that expand and then you measure them with a micrometer) can you get it close enough. You need a solid quality bore gauge kit with a 0.0001" resolution dial indicator. Fowler makes a nice one but their dial indicator is only good to 0.0005" and that's not good enough when you're shooting for a gnat's arse crack sized clearance of 0.0015" between the piston skirt and bore.
Kevin L
'86 Carrera "Larry"
Old 01-31-2019, 01:24 PM
Chain fence eating turbo
Ditto KTL.
Capilers were not even allowed for measuring any F15 engine I did.
Old 01-31-2019, 05:53 PM
Under the radar
Trackrash's Avatar
I used a home made hone with red scotch brite pads. I ran each for about 30 seconds with my electric drill in a dawn solution. I carefully measured each of them before starting. This method works.
Did your machinist use a bore gauge or mic to check your cylinders?
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-31-2019, 06:30 PM
abit off center
cgarr's Avatar
Originally Posted by Tippy View Post
Ditto KTL.
And a good set of gage blocks or master setting ring to set the bore gage
Craig
G2Performance
Old 01-31-2019, 06:56 PM
As a machine shop owner, I can tell you definitively that calipers measuring a bore like that are a no-no.
Just not accurate enough. Also, here is PLENTY of scuffing on that cylinder. If it was me, I'd be sending them off to Millennium to get re-nikasiled and finish bored. Will cost you 1K. They will come back perfect.
You don't want to redo this later.
Old 02-01-2019, 07:26 AM
They are already packed up and spoke with Rod this morning
Old 02-01-2019, 10:01 AM
Attaboy!
Old 02-01-2019, 01:53 PM
