Project Addicted
Excellent Part Cleaner
I try to add value here every once in a while. We are building a 3.4 911 motor here at home and it came out of a 100K mile car. I HATE scrubbing and scraping caked grease off of engine parts for a thousand reasons :-) I decided to buy an Ultrasonic Cleaner that would fit the largest part I would be taking off. On a 911 top end build, the cam towers are the largest parts to be cleaned and they usually have a shed load of grime and stuck gaskets. Lots of little nooks and crannies to dig 25 years of crap out of....
My first mix was tap water, Dawn dish soap and Simple Green. The tank holds about 5 gallons in it so I added a cup of Dawn and Quart of SG. It worked GREAT!! Today I did the cam towers since they have small oil passages that I didn't want to deposit some of the gunk into. Today I used water and Dawn. No SG in the mix. I can't express how well this worked!!! Just as good as the SG added and these parts are SPOTLESS now. No work on my part but the time worked to earn the $$ to buy them :-) This is an excellent parts cleaning investment and would recommend it to any hobbyist. The cost landed at my home was $375.00 and I figure I can always sell it once done if I fond no more really dirty greasy projects to get involved with. Yeah....right!! As a hobbyist, saving on this built quite literally many thousands, this is a small investment. ![]() ![]() ![]() ![]() ![]() ![]()
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
That is cool. Did you order it?
John "Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage |
I am interested to know the make and model. Also where/how did you purchase it?
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
abit off center
110 or 220?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
E-85 sippin drunk
Yep... Spill the beans!!!! Make, model, and place to buy!!! LOL
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Project Addicted
Heres a link
This vendor has many sizes so pick the one that fits yer parts best. No, not those parts, engine parts.... You must use a basket, and it comes with one. This is to keep the parts suspended in the solution while the magic is happening. I have been reading and there are many tricks to cleaning all different parts, little baskets with individual components, like carb parts, to ball jars with special cleaners in them with the parts inside and the UT cleaner only filled with water. 110 volt. Has a heating element that does a very good job of getting the cleaning juice up to 140 for added cleaning help.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 Last edited by Jcslocum; 02-08-2015 at 07:16 PM.. |
Enthusiasm > Expertise
This is awesome -- a "no touch" wash for parts, and much smaller than, say, a dishwasher. Thanks so much for sharing.
I would love to have one large enough to do a crankcase half.
Kartoffelkopf
Excellent stuff! Thanks for the write-up...another gadget to get
![]() I had a medium sized floor standing degreaser tank a few years ago, sold it on the basis that as a home user you couldn't buy decent chemicals to effectively clean stuff...all this namby-pamby eco friendly rubbish, which then goes mouldy when left. For some inexplicable reason, I went and bought another one a couple of years ago for my project; smaller bench top but have used it once. Waste of money...should've got an ultrasonic cleaner and save weeks of my life! For the UK guys, when investigating DRO's a while back, I found this company who also sell U/S cleaning tanks
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
beancounter
Ordered one immediately. Thanks for the tip. I hate cleaning parts.
Tom, I have one like this at work. Ita a 15gallon unit. We also have a larger one that is about twice the size that ran about $10K. The smaller unit was about $5K. They can be found cheap used but are rare as hens teeth. I scour the online gov auction sites but when they pop up cheap they are non close enough to make it an economical buy.
Project Addicted
The cam towers were 30 min per side. 30 min does about 75% of the work, but a quick swish back and forth removes the settled gunge and then I flip them over. Have a beer, come back and take them out. Swish them around and then up to the kitchen sink for a quick rinse and dry. These are the parts where it really pays off. Looks at all the crap in and in there. Standing over a stinky wash tank with mineral spirits running and splashing around... Fugly.....
Some other parts run thru it. Lower valve cover into first cleaner batch: Tap Water, 1qt Simple Green and 1/2 cup Dawn Dish Detergent ![]() Switched on, you can see the "fog" on the right as the magic is happening. This was immediate. Those scrubbing elves got busy! ![]() Valve cover coming out. 45 minutes in the bath. Didn't know how long it will take so just let it go. Look at to color of the water!! ![]() Cam chain housings going in. Water looks bad but still very effective. ![]() Chain housing coming out. Filthy water ![]() Chain housing done. It even loosened 90% of the epoxy on the backs of the housing that was leaking.
Kartoffelkopf
Dag nammit...right, I'm off to rebuild my rebuilt motor now I've seen this! Thanks Jon, you've just set me back 4yrs!!
![]() ...is the Maxwell House in the background your secret recipe
I looked and looked for awhile for a parts cleaner for my rebuild. In the end, I ended up using a speed shop near my home. Two boxes of engine parts ended up costing me $100 to clean so it was worth it to me to do that. I looked at everything from the cheap Harbor Freight stuff to the real nice Northern Tool equipment. Real nice find, especially if you get regular use out of the thing.
Mike '89 CARRERA #402 |
abides.
That's pretty awesome for $375. Does it have a 100% duty cycle?
I wish I had seen that before going through a few cases of brake cleaner trying to get parts decently clean.
Graham 1984 Carrera Targa |
I have a smaller cleaner that I have used with great success for a few years.
I have found that Simple Green will etch aluminum if you leave it in too long - be careful. I have also found that you can readily remove the plating from fasteners and other parts if left in too long. Pinesol seems to be safer on aluminum and plated parts. I have a "dirty bucket" of straight Pinesol that I will soak parts in for a few days and then rinse in the ultrasonic cleaner (usually with just hot water - the carryover from the bucket usually supplies enough soap). Last edited by fanaudical; 02-09-2015 at 06:33 PM.. |
I would rather be driving
This is a great price for a large ultrasonic cleaner.
I had a large one at my old job that I could borrow when needed. I miss it.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
ROW '78 911 Targa
Ordered one, this will work great on the nasty dirty harnesses people send me.
![]() I have a smaller on about 1/3 the size and it just isn't big enough. Price is great. Thanks for posting about it.
I wonder how many of the 35 units sold by this seller are a result of this thread.
Project Addicted
I should be getting a piece of the sales!!!
