matching pistons to Cylinders for 87 911
I have a engine out of a 87 911 that im rebuilding. car sat for a while and had water in the cylinders damaging the pistons. the cylinders are MAHLE nikasil cylinders. I have a good set of SK pistons from a set of alusil cylinders that measure out perfect. Will these pistons work with the nikasil cylinders? thanks in advance!
There should be complete sets of matching pistons, cheap, because people open the cylinders and pistons are left over.
Be sure you match sizes Bruce |
I have a nice set of Mahle 3.2 Euro pistons that would work for you. PM me if you are interested.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Nikasil and Alusil can't be interchanged. Meaning, you can't put alusil pistons in Nikasil cylinders.
1987 Porsche 911 Carrera Coupe |
pistons
Alusil pistons will not work with Nikasil cylinders.........
however, I have a nice set of 3.2 Nikasil pistons, just removed from a very nice running, backdate project..... $150 + shipping for the set. regrds, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I wouldn’t be willing to do the experiment, however, I don’t see why Alusil pistons wouldn’t work. They have a ferrous coating, but that is softer than the Nicasil coating on the cylinders. The reverse is true though. Nicasil pistons cannot be used with Alusil cylinders.
-Andy
72 Carrera RS replica, Spec 911 racer |
I believe it is possible to used the Alusil pistons in Nikasil cylinders as long as the Nikasil rings are used rather than the Alusil rings.
The 9 Store
For $150, Al's pistons are the way to go. That price is a gift.
All used parts sold as is. |
I have this set of 3.2 Euro pistons. I will PM you the details.
regards, al
I should note that I'm not using KS Alusil pistons in Mahle Nikasil cylinders, but rather sent my KS Alusil pistons AND cylinders to EBS Racing in Reno NV, where they had the KS cylinders Nikasil plated and honed to fit my KS pistons, and EBS supplied the rings.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 04-17-2019 at 04:53 PM.. |
All 3.2, weather 9.5 or 10.3 have the same casting numbers
The height of the high side is the difference by several mm. Bruce |
