For me it was cam timing. Every time you tighten the big bolt to the spec tightness it messes with the timing. The crow foot thing does not want to stay on the bolt while applying equal counter pressure to keep the cam from turning.
Chris 73 E |
The Stomski set of specialized tools make some difficult tasks, less so (and a lot more accurate)
Pricey, but after I used one, I no longer had buyers remorse.
Always take the high road, it's far less crowded - Charlie Munger |
send your engine case to Engine Machine Shop by the LAX...they know their stuff
They can balance all the engine parts,crank ,pistons,rods....plus the valve jobs..i took all my engine pieces there for cleaning and machining Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 05-08-2019 at 11:52 AM.. |
That is more local to me than Ollie’s. That said, Ollie’s were super helpful when I called yesterday.
Thanks for the referral Ivan, will ring them. What do you think an all-in machining ballpark cost to do a 2.7 right would be, case savers and heads with new pistons and jugs etc? $4,000 to $6,000?
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
In fact, that was the impetus for starting to build my own cases. I'd say a decent mag case should be minimum 2-3K to do correctly. |
Figure there is about $1500-2000 in extra cost for it being a 2.7 case over a similar condition 3.0 machine work?
You could send it out for machine work etc, and then pay to reassemble. But these are time consuming engines - especially from the case up. Labour of love as much as mechanical skill. You will chew a lot of $s up paying to reassemble. That is obviously a route many take tho and having an experienced builder on the job is peace of mind. There are plenty of things that can go wrong - oil leaks at the case end are really frustrating, incorrect alignment of cam sprockets - expensive wear/tear etc etc. The forum is full of jobs that didn't go quite right - first time. But if you feel competent and up for it, with Waynes book and the forum, you can do it. Don't expect things to move quickly, and don't be in a hurry to finish it. Basically do it once.
Regards Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
well..the prices have changed since i was there last time in 2009 then i departed for Europe..Give them a call ....
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 05-08-2019 at 01:26 PM.. |
Thanks gentlemen
Otherwise you'll really need a helper or 3rd hand.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
There's one other thing that people haven't really addressed here, but bit me in the butt during my rather protracted engine mod process.
Be organized. Very, very, very organized. Especially if you are doing a project like I was where I was interrupted, and there were often weeks I couldn't work on it, and the workshop (hangar in my case) is full of other projects. I lost an entire weekend looking for my scavenge pump. I put stuff in baggies and marked, but still ended up missing items or having items that were unlabeled. You think you'll remember everything. You won't. Take lots of pics, and save them off somewhere organized, as you remove, strip, and disassemble the motor and accessories. Hose routing, orientation of brackets, label connectors with a bit of tape, label which relay or connector is which on the wiring harness.
I have a mag case 2.7 in my 914-6. Nothing else sounds like it. But it is such a ridiculous financial proposition and it comes with no guarantees that it will remain failure free after a rebuild. It's just a crap place to start a build, period end. |
Flightlead - you know Pelican sells the Stomski tool, right? Isn't aluminum a better material for a holder? One of the good things about the Stomski tool is that it comes with a Sterret proper length straight edge. That's top of the line.
I used to try doing this with a metal carpenter's square with the short leg cut off. You can hold it against the intermediate shaft housing and, by being careful, get it true (though it is very easy to have it rock a little and still feel like it is square). Using the depth caliper with one hand is the challenge. My readings were very hard to repeat. A holder does away with all this. Maybe the carpenter's square was true enough for this work (you only need to be as close as the shims allow), or maybe not. |
1. Sealing the case
2. Cam Timing. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al
Under the radar
OK. Here goes.
Placing the two case halves together, making SURE, the oil pump seals stayed put. Installing the piston circlips. The tool is a MUST with JE pistons. You may want to buy a couple of spares, AHIK. And yea, timing the cams with the new style bolt, good luck.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-10-2019 at 05:39 PM.. |
Circlips....+1...the Stomski tool is a must.
Under the radar
I made my own. Not hard to do.
