1985 3.4 build using MAF 279.56 HP, 237.63 RWHP
This winter I decided to enhance my 1985 Euro. I use it for fun, hasn't been to the track and may never make it there. It was smoking from worn valve guides. One thing led to another and pretty soon I had increased the displacement to a 3.4, twin plugs, MAF etc. I needed to stay with 91 octane since it is the only reliable choice here in the midwest.
It previously ran quite well with a SW chip and B&B Headers with a 2 in 2 out design. Terry Worick from Lincoln, NE was the builder and was a great resource for choosing which modifications for me and Sal Carceller worked his magic on the MAF and chip. It runs great. It has more of a motorcycle feel to acceleration. Actually very smooth and the cam doesn't feel lumpy at all. The torque comes out to be 253 ft/lbs at the crank, the curve is excellent: Wheel torque #s 3000RPMs = 182lb 3500RPMs = 190lb 4000RPMs = 193lb 4500RPMs = 200lb Here is the lengthly list of the engine/clutch modifications: Displacement increase 95mm cylinders to 98 mm Mahle cylinders ARP rod bolts in stock rods ARP Head studs JE pistons 10.5 to 1 total seal piston rings Heads rebuilt by Competition Engineering Machined for twin plug Competition valve job DC 21 Cams Performance springs and titanium retainers extrude honed 3.2 intake manifold B & B Headers and dual out mufflers Light weight fly wheel Upgraded pressure plate Ignition modifications 964 Twin distributor Andel Splitter Fuel injection modifications: Enlarged throttle body by Steve Wong Larger injectors from Sal Sal Carceller MAF and DME Thanks for all the inspiration from previous builds and big thanks to Terry and Sal for the hard work making it run great. This is a disease I started thinking about suspension mods today....... more pictures to follow ![]() Dyno ![]() Engine out ready for surgery ![]() Dirty oily mess ![]() Pistons JE 10.5:1
85 911 ROW Targa Last edited by 85MytFast; 06-21-2015 at 04:53 PM.. |
More Pictures
![]() Splitter ![]() Pistons and Cylinders in ![]() Valve Train ![]() Glamour Shot
85 911 ROW Targa |
Couple more
![]() Fully in with MAF ![]() New gauge to monitor AFRs ![]() DC21 ![]() Ready to install
85 911 ROW Targa Last edited by 85MytFast; 06-21-2015 at 12:27 PM.. |
Rick,
This was a fun project to work on. What I find amazing about this build is the low end torque and HP below 4000RPMs. This area in the motor simply shines! For a street car the recipe you have come up with is most interesting. I give a lot of credit to Terry who helped design this motor mechanically. I've seen plenty of motors generate a lot of torque and HP in the hi-RPM range 5800-6500RPMs and this engine is no slouch in that area but it out paces most everything else I've seen below 5000RPMs and is really amazing even at 2500RPMs. On the street this car must certainly be a blast to drive. Enjoy the hell out of it. That dyno run you posted was the last one we did on a near 95Deg day!
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
abit off center
Thats the same motor I built years ago with the same cams, what overlap did you end up setting the cams at?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
The cams are set at 2mm as specified by John Daughtery.
Great dyno numbers! Digesting this build components and numbers vs another sal did prior. What elevation was the dyno? Still up in Denver?
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 11-11-2015 at 05:45 AM.. |
Dyno reported air pressure at 28.58 in/Hg I believe that's about 1300-1500 feet or so by math calc. I think Rick or Terry could answer best where this dyno shop was located. I know it was not at any significant elevation. We did most of the tune at a Mustang dyno (Load Dyno) but those numbers can be tricky to interpret so Rick decided to have the final pulls done on a Dynojet (Inertia Dyno) for comparison to other motors.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 06-28-2015 at 11:04 AM.. |
Lincoln is at 1200' elevation. I run to Colorado usually in the summer once so I will be curious how it handles Fall River Road over the divide. Still running smooth and pulling strong.
85 911 ROW Targa |
The other motor I helped tune was single plug and it ran super strong but this twin plug motor in this thread made some amazing torque in the 2500-4500 RPM area, I was pleasantly surprised by the low RPM numbers. For a street car this is a great build.
Very Nice Build
Would you happen to know the size of your B&B headers - they are measured by outside diameter of the tubes: 1.625" (1 & 5/8"), or 1.75"?
Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa |
I believe they are 1.75". I have their 2 in 2 out muffler. There is some drone between about 2500-2900 rpm. They sound pretty awesome when pushing the revs.
85 911 ROW Targa |
FPOR-0410 on the headers. I wanted the heat exchangers.
85 911 ROW Targa |
Schleprock
Nice choice using the JE pistons in lieu of the factory 10.3:1 pistons with those cams. The piston-to-valve clearance can be pretty darn tight with the factory pistons, even with cams that do not have high lift + larger lift spec @ overlap. In other words, 2mm is not a huge timing spec.
Just yesterday I timed a set of 964 cams (1.26mm lift spec) in a '87 USA 3.2L with stock pistons and the clearance is pretty tight. Setting up the left (1-2-3) cam with the baseline starting point method of placing the dot on the end of the cam at 12 o'clock, we found that the #1 intake valve was touching the piston as we approached the overlap point on the crank pulley (TDC #4). Granted, this is an engine that's had at least two top end services done in ~170K. So the heads have been resurfaced a tiny bit and that will reduce the piston-to-valve clearance.
Kevin L '86 Carrera "Larry" Last edited by KTL; 06-29-2015 at 07:23 AM.. Reason: added 964 cam reference- duh, that's pretty important |
The owner (Rick) and the engine builder (Terry) are already thinking about trying a more aggressive cam later in the Fall or Winter. They are thinking of a DC cam but a more aggressive cam, I'll let Terry or Rick comment on the cam they have in mind. A common worry with the stock intake is pulse reversion and the AFM but with my MAF setup it's very tolerant with reversion. My MAF only meters air in one direction, unlike many hot wire MAFs. The design of the MAF is such that it can't see reverse air flow through the tube. This is why even with the DC 21 cams this motor idles perfect.
Schleprock
Sal,
I edited my post to clarify that I was timing 964 cams, since I failed to mention that. I mention the tight clearance too because I had similar difficulty with my own '87 USA 3.2L when I installed DC-20 cams. That cam's lift spec is 2.2-2.4mm. When I set the spec to 2.3mm, I found I only had 1mm of clearance (intake typically should have at least 1.5mm) and I found that I had to reduce the lift spec to 1.85mm. The swirl dome on top of the Motronic pistons (on the intake side of the piston) makes for tight valve clearance. The exhaust side of the piston is flat & therefore there's not much risk of tight valve clearance there. I'm not saying the DC cams are inappropriate. Just pointing out that we have to be sure we investigate the piston-to-valve clearance. While these cams we're talking about are not truly high lift cams by their timing spec., they still have a high amount of actual valve lift. Plus, the shape of the lobe is such that the closing event of the intake valve allows the piston to get closer to the valve as the piston is going upward and "chasing" the intake valve toward TDC. Good point about the hotwire MAF being more tolerant to intake pulse reversion as compared to the original "barn door" air flow meter. I assume that is a big plus in letting people get more aggressive with cam selection?
Kevin L '86 Carrera "Larry" |
Hot wire is not a good choice MAF nor is the factory AFM, they both are very effected by pulse reversion. The MAF I use is not Hot Wire, it's a special Lab grade MAF and has very unique design for air flow that only meters in one direction. This is key when using aggressive cams and trying to properly meter air flow. How aggressive I can get on cams I'm not sure yet but I think Rick is willing to try more aggressive cams later in the year on this motor.
Schleprock
Thanks for the clarification on the type of MAF. From a basic logic standpoint, you'd think metering in only one direction would be obvious. As in, why would we even care about metering flow in the reverse direction in the case of an engine. But i'm admittedly VERY ignorant to what are the important aspects of engine management in part-throttle or no-throttle conditions!
Cars Ruined My Life
Wonder what this would do on 93 oct
93 octane would not matter much in this motor. It tolerated peak ignition even on 91 octane fuel. Most likely the lower 10.5:1 compression with twin plug helped. Basically this engine design is not very detonation prone.
