abit off center
Saving an old 2.7 case
What did I have to loose? So far so good, also added supports to mains: and took about 4 thou off the case halves: Reposted from GruppeB, you know, GruppeB those cheap Bas**rds
Well, Just got done center boring the case back to standard, This worked out so much better than I thought it ever would, I guess all that measuring and testing paid off. Here are some pics of the process. I then cleaned up the old bearings, set the crank and bolted it up to see if I was even close. This thing turns soooooo nice, I was surprised to tell you the truth. i dont know what the clearance is yet because I did not plastigauge it but the center main bores are within .0002 of standard. I guess all those nights setting up and resetting the reamer paid off. Cutting the mains ![]() Checking the finished bores ![]() Setting the crank
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Nice!
JPIII Early Boxster |
abit off center
Oil bypass mod done!
Craig,
What's the history of this project, was this a line bore to standard following surfacing of the case, or to oversize with the case the way it was? On one hand, the bearing webs look like they have been surfaced, but on the other I see some red dye at the upper right and the right half has an M10 and two M8 studs installed, which makes it hard to surface
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
abit off center
The plan was to bring the mains back to standard, the mains were oval shaped as many are in these cases, I took the case down as far as I dare, (all studs removed) the only area which is about a thou off is where the red dye is but that is not a critical area and it still bolts up well, next I used my jig to ream the main webs for the insert guides, then installed the necessary studs to bolt the case back together and bored the mains, next will be to cut the lay shaft bearings and the flywheel seal area. I didn't want to take off so much as to alter the chain boxes. I still have the casesavers to install but didn't want to do that until I knew I could bore it back to standard. Remember I really never thought this would work, it was a junk case and really only started as a personal challenge, I was running out of things to do! I'm almost 50 and been married for 20 years if you know what I mean!
Nicely done, Sir.
![]() IMHO, this should SOP for ALL mag cases, nowadays.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
abit off center
After whipping out a home made cutter on the lathe I cut the rear main seal in the case.
thats a great jobs. I like to do a lot of stuff by my self because I consider it a challenge.
Craig, I think that you have do a lot of machine shop works, do you have a special procedures to remove the rusty cylinder heads exhaust studs? Mines are no broken yet, but in very very bad shape that I would like to replace all with a new ones.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Lotus 23 Lotus 7 TVR Vixen TR3 914-6 Clone 914-4 X-Runner |
abit off center
Repaired the badly corroded oil relief tube with an aluminum sleeve, reamed to oversize and made a sleeve, only thing to do is re drill the ports.
That will be a good motor to test in the 74 when the body is completed
Denny 1976 911s targa 1974 widebody G2 style GroupeB 76 www.G2Performanceshop.com Cylinder head recon, case savers,twin plug,rocker arms |
Craig, did you use an interference fit on the oil tube?
abit off center
It was just a light press/slip in fit, and I bonded it in. The problem was I finished bored the center for the piston first and if I had to press it in then the bore would have been changed. If I was to do it again I would have pressed it in leaving the inside a tad smaller then reamed the bore to 15mm
abit off center
Yea but its going to be a long time with only one sponsor so far, there is plenty of body panels for others!!!
man, if I lived near you I'd be camped outside your shop until you taught me what you know.
We actually have two shops......one for the clean work and the other for the rest
I'm about to build one (shop) for my stuff. Looking for a spare 2.4 or 2.7 to build. The 2.2 I built has over 1500 miles on it and is running better each time I drive it so I'm fairly confident she'll hold together. The 2.4 or whatever I get will take what I learned from that a couple of steps further. Nice looking machine work your doing there.
Sleeving the bore was a good idea, but did you consider using Bronze or Stainless for the sleeve?
I have R&O'd a bunch of piston-in-bore apps using Bronze, and I find the long term results are better with the harder material. Also...when cutting the side openings in the newly sleeved tube, you might want to back cut the edges to prevent early galling of the piston. Good job Bob
Bob Hutson |
abit off center
![]() [IMG] [/IMG]
abit off center
Had to make a new plug since the reamer took out the original case threads. New threads are 3/4-20
