mounting cam gear question
After installing the cam sprocket over 3 shims and the main washer there is only about 1/16" showing on the cam for the chain gear to mount. Is this normal?? Seems a little odd to me.
Cosmo
Irrationally exuberant
The chain sprocket will not slide completely onto the cam shaft but it should slide on more than 1/16". Make sure the inner gear is pressed on all the way.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Author of "101 Projects"
Which sprocket are you talking about? The big one, or the smaller one?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
that would be because the cam is not up against the thrust plate. pry it toward the plate with a screwdriver behind whatever lobe you can get a bite on. they move easily.
