I do hope you get to nail the cause before the rebuild. I take on board what Neil says (as do you) with gold plating. But I could not sleep if rebuilding again and not knowing where it went wrong. The worry is inadvertently making the same mistake twice. With these complex engines, could be the simplest of things to overlook. Good luck and commiserations. I think we all feel the pain, knowing the hrs and $s to get that far. Can't add anything really - agree the source of the muck is an issue but unlikely to be the cause of the noise. The torn bit on the thrust bearing would worry me.
I did a crankshaft up rebuild on my SC about 10 yrs ago. Ended up with a noise and could feel a knock in one cylinder. Worried me enough to tear down the top half again :-(. Found nothing. Put back together and still running great 30k later, no noise, no oil burn, no leaks. Explain that. Don't bother - you have enough to contemplate. Best of luck Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I've taken apart several 70-80s Ferrari motors that were 'running fine', just worn. No clicking sounds, still on factory builds and internals, and found rod and main clearances far and away out of factory clearances with upwards of .005. One Boxer engine had .008 on one of the main journals. Saw a Countach engine with the same main bearing issue. They ran fine before. Bizarre that some of these issues do not audibly articulate themselves yet some other seemingly mundane issue does.
What type of oil filter was being used when the engine was first run? I say this because some filters have a constantly open internal bypass, or can have a very weak internal bypass, meaning unfiltered oil is allowed to just re-enter the engine if a certain pressure is realized. All that fresh engine shrapnel heading straight back into the engine can cause the damages in question sans the oil ring.
No physical quantity completely explains its own existence |
Without going thru the pages again, I think your original engine before rebuild, did not have that kind of trash wear/damage? If that is correct, the damage has to be from the rebuild, not trash missed in the clean up. Seems like your engine was cleaned out pretty good. Maybe some small bits (hoses etc) missed, but the trash has to have come since reassembly. If that is correct, the source should be obvious. Has to come from somewhere. Can you post clsoe up pics of the top and bottom halves of the bearing that seems to have damage. May be poking at shadows, but this has to be solveable .
Regards Alan
"I've taken apart several 70-80s Ferrari motors that were 'running fine', just worn. No clicking sounds, still on factory builds and internals, and found rod and main clearances far and away out of factory clearances with upwards of .005. One Boxer engine had .008 on one of the main journals."
If the oil pump has enough capacity (volume) to maintain oil pressure at the large clearances and a high viscosity oil is used that is entirely possible. Might be a little noisy on start-up though. |
Work in Progress
I did use Porsche bearings when I rebuilt the engine. My understanding is that they are 996 GT3 bearings.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Work in Progress
Work in Progress
I'll look again at the layshaft gear. It looked Ok when I first inspected it, (no pitting or cracked teeth). I did use new chains, and new sprockets. The chain (particularly 1-2-3 Side) could have been rubbing. The case definetly has some wear on the pathway between the IMS and the Cam sprocket. Only problem is I'm just not sure if this wear was there before or not. None of my old photos of the case have this area photographed too well. I do remember there was some wear on this area, but I genuinely can't remember if it was this bad or not. I totally remember the green arrows, I just can't recall if the orange was there before or not.
Work in Progress
I haven't taken the heads off the cam towers yet. When I do I'll take a better look at those. I don't think a valve is loose but will check.
Work in Progress
I did have one idea of shrapnel. I did use my original 3ldz on the car first after the rebuild, and had to have my drip tank modified to have a longer neck to allow for the bigger borg warner turbo. I tried to clean this out pretty well before I put it back in the car, but maybe there was leftover material from when someone welded on a longer neck. Possible that is where it came from.
Looks like something was VERY misaligned in your case... You wore out your thrust bearings... You wore out the thrust surface of the IMS... and your chain ate into the case... Could you have put the cam gear sprocket on wrong? If your chain alignment were WAAAYYYY off, that might explain the IMW wear, chain wear, and possibly the main thrust bearing wear. Then, the aluminum shrapnel where the chain ate the case, destroyed the bearings... Might also explain the knocking, as the chain was hitting the case... You sure its the right chain you bought? Cam gear on right (one is supposed to be inverted on install)? |
Derrick |
Work in Progress
Hey guys,
I know this is not really relevant to my build as I used JE pistons and not stock pistons. But earlier in the thread we did have a conversation about the offset in piston pin. I am working on building an excel worksheet for all the measurements I have to take, and came across this bit of information from the workshop manuals. Appears as though the factory did offset the pistons in 930's at least. I took a photo of the page in my workshop manuals:
Bingo - flat topped pistons, no valve reliefs, physically you can install them with the arrow pointing either way, but with a pin offset one way is anti-slap, and the other not.
Were all the arrows (or whatever the installation mark is) pointing at the flywheel? But do I remember this engine ran fine for a fair while, then developed the sound, which (perhaps serendipitously) led you to disassemble it and find the bearing issues? Those marks on the chain housing don't look good. Shouldn't be any at all, ever. However, if the chain wheel on that side was installed out when it should have been in, again I'd have thought you'd hear it right off the bat. Was the tensioner nice and stiff on that side? You have to squeeze it in a vice to reinstall the pin so you can reinstall it? I don't suppose you saved a sample of your oil? Which could be analyzed for metal content? |
Interesting. I just pulled an old Mahle 930 "97+" piston out of the shed. It is indeed offset 1mm. This particular piston had valve reliefs in it too. After measuring, the valve reliefs are the same diameter (arc) of the intake valve, so it could presumably go either way, with a mark similar to that in the pic.
Measure the offset on one of your JE's. It could have been that you installed one upside down and didn't realize it. |
Work in Progress
My ticking noise started right away after the rebuild. I voiced some concerns but most thought it was just valve related and would go away once they were adjusted. I did not have stock pistons so that is one mistake I couldn’t have made. My pistons had larger reliefs for the intake valve so that made it easy to install them right side up. I also checked my assembly and disassembly photos and they showed that I had the pistons orientated correctly. I do have some oil saved and some pockets in the engine that Are still there. After looking at the case for a while today pondering things I genuinely believe that wear on the case was from a time in the past, and not this rebuild. Simply because there is still sealant on the edges where the chain housing meets the case that would have been worn off had the chain been rubbing. In addition to that my chains show no indication of being temporary grinders. I’m sure the steel is harder than the aluminum case but I’d imagine they’d show something from that. Any reason why it would only make the noise when it was warm? My ticking only happened as the engine heated up. I think as Neil mentioned this build is going to have to be carefully measured and everything checked and rechecked. My tensioners were good when I put them in. I’m almost 100% positive the cam gears were orientated correctly. I did use the stromski straight edge tool to measure them when I assembled it. I’m also pretty darn sure the gears on the intermediate shaft were put on correctly, but those I can check. Thanks.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 Last edited by Rich76_911s; 07-02-2019 at 07:59 PM.. |
OK, lets assume that everything was installed correctly. I thought the noise was from #6 cylinder area, do you concur?
If so, that narrows the microscope down to a single cylinder, and you have 5 "good" ones with which to compare. Check piston to wall clearance, small end rod bushing, big end bearing clearance, piston skirt, etc. Compare those to the other cylinders. It's gotta be something. If these engines weren't so darned labor intensive, I'd just say swap parts with one of the quiet cylinders. But at least you have those for comparison. And measure the pin offset on the JE's, just for comparison. |
(man/dude)
Just a thought on the ticking, could the non-broken #6 oil ring have been clacking back and forth in the groove as the piston reversed direction? It would be somewhat non supported for the portion that was missing the other side.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 07-25-2019 at 03:16 PM.. |
I've had ticking from improperly reground cams.
Ok crazy idea, don’t even know if it’s possible...
Could your chain have been riding on only one sprocket of the intermediate shaft? It’s supposed to ride on both, as it’s a double chain... I was throwing on my cam thrust plate today, in my eternal rebuild. Somehow the chain popped of the ims sprocket. It was a bear to get it on. At one point, it was riding on only 1 sprocket not two. Had to take all the chain ramps off to put on properly... This is only a theory, and I have no way of knowing if it’s even possible... If you assembled the motor with the chain on one sprocket, could the motor spin over, grind the case and sprockets enough to throw debris all over, then pop onto both sprockets??? Sure would explain your case being ground down, the shrapnel, and everything else... In this scenario the cam sprockets measure out correctly. The chain is on the cam sprocket correctly...but it’s shifted on the ims double sprocket... |
