3.0 upgrade tach problem
just completed 2.7 to 3.0 swap. Everything is fine except that the tach doesn't work. Is this a wiring issue or do i need an sc tach?
Have you found an answer yet? I’m having the same problem..
Thanks |
I dunno - I had an SC tach in my '75 and swapped it straight for a '74 tach - it worked fine.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
drag racing the short bus
My '74 tach works fine with my SC engine. Try putting the old tach back in, and if it works, leave it.
The Terror of Tiny Town |
Author of "101 Projects"
Sounds like a wiring issue to me. Check the harness...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hey Novice...How did you hook up the engine bay wiring for your 77'...and how did the ECU hook up go.???? Thanks Frank with the exact same upgrade ...
