67 S 911 distributor curves.
Hi.
My 68 911 has a 67S engine that is yet to run.
I'm getting it ready for a start soon.
My distributor is a 001 which I believe is the 68 911 distributor.
It should have a 002 I believe.
Shall I get it re curved or will it be fine for a weekend driver.
Here in Australia we have 91 95 and 98 fuel.
Thanks Lyndon
Old 09-06-2019, 10:22 PM
Under the radar
Trackrash's Avatar
The only curves I can find in the original repair manual. The S curve should work.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-08-2019, 06:41 PM
I've got that. The std 68 911 is a little different.
I'm guessing as a run about it be fine as it not to different. They both have the same dynamic at 6000 rpm
Thanks Lyndon.
Old 09-08-2019, 07:27 PM
Under the radar
Trackrash's Avatar
I think if you used the S curve for a guide you should be in the ball park. With the S cam and compression, which I think was the same for all the 2,0s, there is somewhat less advance. Should be easy to adjust your distributor's curve to match.
Gordon
Old 09-09-2019, 07:10 AM
Great. Thanks I will look into getting it done.
Lyndon
Old 09-09-2019, 10:04 AM
BURN-BROS's Avatar
1967S curve is a pretty nice one.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 09-11-2019, 11:27 AM
