-   -   Fun supertec 2.8ss build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1043243-fun-supertec-2-8ss-build.html)
Steve F 10-25-2019 04:37 AM
Awesome Henry!! What is the green material on the cylinder base as the piston is being inserted please?
lvporschepilot 10-25-2019 06:23 AM
Originally Posted by Steve F (Post 10635330)
Awesome Henery!! What is the green material on the cylinder base as the piston is being inserted please?
Curil T sealant
Steve F 10-25-2019 06:46 AM
Thank you.....Henry, sorry I spelled your name wrong....fat fingered ithttp://forums.pelicanparts.com/support/smileys/wat5.gif
Bigtoe32067 10-25-2019 06:53 PM
That is the cleanest straightest line of Curil T I’ve ever seen. I get it all over the place. Henry is a Curil T artist. Props
Tony
camgrinder 10-26-2019 02:59 PM
Originally Posted by Henry Schmidt (Post 10634451)
The DC62 is not on Dougherty Racing Cams Porsche 911, 930 and 964 camshaft profiles website but I have experience with the cam so he still makes it on request.
John does great work and I tend to stick with what works/has worked.
Thanks Henry
fanaudical 10-26-2019 06:35 PM
Gorgeous!
911pcars 10-28-2019 06:15 PM
Very nice. Did I miss the fine print (asking price)?
Of course, if I have to ask ............
Sherwood
Henry Schmidt 10-29-2019 03:51 PM
Sherwood
More than you want to spend but less than you think.
Singer (Ed Pink) stratosphere numbers.....no
Shade-tree numbers.....no again.
coomo 10-30-2019 11:15 AM
Henry do you have your cases vapor cleaned? It still appears that some controversy remains ,as to whether its "safe"
jbell959 10-30-2019 06:53 PM
Spent the afternoon at Henry's shop and this engine looks even better in person. It's a work of art!
onboost 10-31-2019 07:51 AM
Jee-zus!
Always a tasty build from Supertec!
Thx for sharing!!
Kemo 10-31-2019 12:10 PM
thanks for posting! Awesome build, I bet it pulls like a beast!
jbell959 11-01-2019 06:56 AM
Not high butterflies, but here's my beautiful set of rebuilt throttle bodies for the 70E sporto I'm putting back together. Henry and his crew do some nice work.
http://forums.pelicanparts.com/uploa...1572616427.jpg
Turbo_pro 11-02-2019 12:53 PM
There's a lot going on with this pump. Can you tell us about it?
dkirk 11-03-2019 10:26 AM
Stunningly beautiful work Henry! Thanks for your detailed post.
Henry Schmidt 11-05-2019 05:42 AM
The pump mods are items we've developed over the years to enhance reliability and function, not to mention a touch of WOW. The trick bits are ours but the magic tuning was performed by Mark Jung @ MFI Werks.
First the RSR replica cover was designed and manufactured by Aaron Burnham exclusively for Supertec. As you can see, it's work of art. It varies from the original RSR cover in that it has a boss to mount our enrichment device. The original thermostat can also be mounted.
http://forums.pelicanparts.com/uploa...1572959950.jpg
This is a cable operated enrichment device that allows the drive to control the mixture for start up. This is the 3rd generation and we believe the improvements move it to the next level. If you own a 1st or 2nd generation device, we would be happy to up-grade yours for no charge. Simply send it back
Years ago we decided that hot engine oil in the pump made sense only if you ran a cold start thermostat. So with a enrichment device, sealing the pump was a no brainer.
As the pump heats up, pressure builds inside so if you seal the pump you have to run a breather. We made this breather a bolt on item the make it user friendly.
The fuel fitting were originally designed to accommodate the tight space engine compartment on a 917 replica. We were so happy with the results we decided to add it to our list of products.
Making custom fuels to match the fitting was the logical next step.
47silver 11-05-2019 09:42 AM
fantastic!
Jeff Alton 11-07-2019 08:32 PM
Nice looking bits there Henry!
starchy 911sc 11-16-2019 01:48 PM
Henry, tell us a bit more about the ITG vs the K&N filters used in your earlier high performance builds please.
Do the ITG’s have superior air flow? Does it just come down to aesthetics?
I note the ITG’s come with base plates that allow custom mounting/machining to mag, plastic or individual stacks to match the intakes. This seems to be more flexible than the K&N option which is predrilled for carbs.
Regards,
Andrew
Henry Schmidt 11-17-2019 06:48 AM
Regards,
Andrew
The choice has a little bit to do with a multitude of variables.
First, dyno sheets show an increase in performance with air filters installed vs. no air filter. We did not do a comparative dyno run with K&N.
Aesthetics is always a consideration. ITGs offer high quality filtration with a "period correct" feel.
Perhaps the largest factor is the universal appeal of the ITG. They allow us to custom fit them to a plethora of custom intakes.
We're really happy with the way they fit on our custom high butterfly stacks.
With ITG air filters
http://forums.pelicanparts.com/uploa...1574001533.png
Without air filters
http://forums.pelicanparts.com/uploa...1574001128.JPG
http://forums.pelicanparts.com/uploa...1574001291.jpg
