This is definitely the "sharp end of the stick", as my engineer Dad would say, and a pleasure and priviledge to see...behind-the-scenes peek.
Basic question: would the engine make better numbers WITH the filters because the filtration media somehow creates favorable characteristics to the airflow...as in, the foam either straightens it out or swirls it up? Thanks, John/CT |
I want one!
I just had a customer as m about this build so I thoughts it was time for a refresher.
We build more 3.2 Short Stroke motors now...More is better ....right? http://forums.pelicanparts.com/uploa...1734028005.JPG |
Our newest version of high butterfly air filter stacks.
We can offset the filter bases to allows for better fitment. Left side towards front pulley and the right side towards the flywheel. http://forums.pelicanparts.com/uploa...1734028343.JPG http://forums.pelicanparts.com/uploa...1734028343.JPG http://forums.pelicanparts.com/uploa...1734028343.JPG http://forums.pelicanparts.com/uploa...1734029520.jpg |
Henry,
is this motor on an SC case? thanks for posting! |
The 2.8 SS uses a 66mm SuperCrank and the 3.2 SS uses a 3.0 70.4 mm crank. 2.8 SS is a 95 X 66 mm Bore and stroke. The 3.2 SS uses a 98 X 70.4mm bore and stroke. They both use a version of a 130mm GT3 rod. |
