Try not, Do or Do not
Fun supertec 2.8ss build
2.8 liter Hi Performance Street Engine ( 95X66)
95mm 10.0 TO 1 COMPRESSION CP X FORGING PISTONS W/LIGHTWEIGHT PINS MAHLE CYLINDERS 95mm 3.0 911SC ALUMINUM CASE BILLET SUPERTEC SUPER-CRANK 9 BOLT 66 mm stroke , GT3 ROD JOURNALS RECONDITIONED GT3 PANKL TI RODS W/ NEW WR BOLTS DRC BILLET CAM SHAFTS (DC62 102 LC ) SUPERTEC 49MM CAM SEAL BIG PORT 911 SC CYLINDER HEADS 40 MM INTAKE PORTS 38MM EXHAUST WELDED CIS NOTCH SUPERTEC HEAD STUDS AASCO VALVE SPRINGS SUPERTEC TITANIUM VALVE RETAINER MAIN BEARINGS (GT3 RED) ROD BEARINGS (CLEVITE) DRY FILM COATED INTERMEDIATE SHAFT BEARINGS 996 TWIN TURBO OIL PUMP IWIS COMPETITION TIMING CHAINS SUPERTEC TENSIONER ARMS CARRERA CHAIN TENSIONERS SUPERTEC RECONDITION ROCKERS AND SHAFTS ENGINE BALANCE .5 GRAMS VALVE JOB W SILICON / BRONZE GUIDES CUSTOM PLUG WIRES CUSTOM 964 STYLE VALVE COVERS, CUSTOM BUILT MFI PUMP (MFI WERKS) SUPERTEC NYLON 11 FUEL LINES MFI HEAD CONVERSION SUPERTEC COLD START DEVICE SUPERTEC RSR PUMP COVER AND BREATHER HIGH BUTTERFLY INTAKE & SUPERTEC ALUMINUM STACKS W/ ITG FILTERS SUPERTEC GEN III TWIN PLUG DISTRIBUTOR (AARON BURNHAM INPUT) SUPERTEC PLUG WIRE AND CONNECTOR HOLDERS BURNHAM PERFORMANCE SUMP COVER BLAST CASE & REPLACE GALLEY PLUGS STAINLESS STEEL HEADERS DANSK SPORT MUFFLER AMBER FAN SHROUD & PERIMETER TIN (SERIES 900) 228 FAN AND HOUSING RESTORED IN-HOUSE NEW 75 AMP ALTERNATOR CUSTOM IGNITION HARNESS
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Super serious ($$$) and beautiful ($$$) motor. Congrats. Doesn't Dougherty call the cam the DC65 cam and not the DC62 cam now? That's how it is on his website anyway. I *love* this camshaft. Love the build. That should be a 290-300bhp motor.
No physical quantity completely explains its own existence |
A wow motor from Henry
The high butterfly just gives it the look.How about a video when you dyno it for some sound symphony.
Beautiful build Henry! How about some power spec’s
Thanks. |
Very cool. I love the ITG filters on the high butterflies.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
I can't have dirt inn a fresh motor, screens only keep out rocks and bugs.
ITG filter conversions are our latest product. We take our aluminum stacks and machine them to mate together after installing a filter plate.
I need a set of those. We'll talk when I come pick up the throttle bodies. I love the ITG filters on my 2.5
Under the radar
High throttle body injection, 12 plug dizzy, 228 fan, Ti rods, MFI. My dream motor. Yea when I win the lotto, I'll have one like this.
Just another 2.8ss gem from Supertec
Well done Henry on another fine build!
Were the high butterfly TB’s sourced from TwinSpark Racing? |
They were usable as delivered. We put them through our rebuild process, including the flow bench and now they pass our QC.
Henry, awesome build. Curious where you see the power band for this motor..
Looks really good Henry!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I’d hang it from a big ass gold chain and wear it around my neck with my shirt unbuttoned. Damn that engine is sweet.
Tony |
Man.....just beautiful.
'71 914-6 #0372 '17 Macan GTS |
John does great work and I tend to stick with what works/has worked.
Here's chart from a similar engine (same ignition, porting, cams, MFI, comp) a few years ago.
