This is definitely the "sharp end of the stick", as my engineer Dad would say, and a pleasure and priviledge to see...behind-the-scenes peek.
Basic question: would the engine make better numbers WITH the filters because the filtration media somehow creates favorable characteristics to the airflow...as in, the foam either straightens it out or swirls it up? Thanks, John/CT
Old 11-17-2019, 08:33 AM
clutch-monkey's Avatar
Originally Posted by Henry Schmidt View Post
The choice has a little bit to do with a multitude of variables.
First, dyno sheets show an increase in performance with air filters installed vs. no air filter. We did not do a comparative dyno run with K&N.
Aesthetics is always a consideration. ITGs offer high quality filtration with a "period correct" feel.
Perhaps the largest factor is the universal appeal of the ITG. They allow us to custom fit them to a plethora of custom intakes.
We're really happy with the way they fit on our custom high butterfly stacks.
i used to have data somewhere from another forum where a user tested it ITG/pipercross/K&N and from memory the data showed the ITG had the best flow/particle filtration of the lot- pipercross close behind.
curious about this too, i know the stock Rx8 intake for example there is even a fine mesh or something that straightens airflow etc so could well be?
Old 11-17-2019, 03:21 PM
I want one!
Old 01-14-2021, 05:30 PM
Try not, Do or Do not
Henry Schmidt's Avatar
My personal feeling is that some may flow better than others but they all flow enough for the two valve engines we build.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-15-2021, 09:59 AM
I just had a customer as m about this build so I thoughts it was time for a refresher.
We build more 3.2 Short Stroke motors now...More is better ....right?
Henry Schmidt
Ph: 760-728-3062
Old 12-12-2024, 10:26 AM
Our newest version of high butterfly air filter stacks.
We can offset the filter bases to allows for better fitment. Left side towards front pulley and the right side towards the flywheel.
Henry Schmidt
Ph: 760-728-3062
Old 12-12-2024, 10:53 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Henry,
is this motor on an SC case?
thanks for posting!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 12-12-2024, 12:48 PM
Originally Posted by Kemo View Post
Henry,
thanks for posting!
Both engines were built using an SC engine case.
The 2.8 SS uses a 66mm SuperCrank and the 3.2 SS uses a 3.0 70.4 mm crank.
2.8 SS is a 95 X 66 mm Bore and stroke. The 3.2 SS uses a 98 X 70.4mm bore and stroke.
They both use a version of a 130mm GT3 rod.
Henry Schmidt
Ph: 760-728-3062
Old 12-12-2024, 01:37 PM
