cosmo's Avatar
mounting cam gear question
After installing the cam sprocket over 3 shims and the main washer there is only about 1/16" showing on the cam for the chain gear to mount. Is this normal?? Seems a little odd to me.
Cosmo
Old 03-31-2003, 09:08 AM
Irrationally exuberant
ChrisBennet's Avatar
The chain sprocket will not slide completely onto the cam shaft but it should slide on more than 1/16". Make sure the inner gear is pressed on all the way.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-31-2003, 11:36 AM
that would be because the cam is not up against the thrust plate. pry it toward the plate with a screwdriver behind whatever lobe you can get a bite on. they move easily.
206 637 4071
Old 03-31-2003, 07:00 PM
