Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by Martinlassmann View Post
4mm with an early 4 rip pump or 964?
Pump makes no difference.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-05-2021, 09:43 AM
burgermeister's Avatar
What my rockers looked like. This is <15,000 miles of driving using BP20W50 oil.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-05-2021, 10:41 AM
Meister,
Are these the one's you had reworked? If so, how are they doing?
Phil
Old 02-05-2021, 11:05 AM
Yep, John reground that set. I have not checked it over in detail, but I do peek at whatever cam lobes are visible at the annual valve adjustment, and I have not found anything. Mileage on the set is probably 20-25K. A decent amount of track use initially, though only a 2 day weekend in the last 2 years.
Old 02-05-2021, 01:42 PM
Harpo's Avatar
Thanks Henry, good to know, thanks for sharing!
Originally Posted by Henry Schmidt View Post
In my opinion the factory oil cam feed restrictor is too small.
From memory... 2.5mm. The non-restricted fitting is 6mm.
We modify the opening to 4mm. This gives us the best of both worlds.
Old 02-07-2021, 03:09 PM
