Try not, Do or Do not
Pump makes no difference.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
What my rockers looked like. This is <15,000 miles of driving using BP20W50 oil.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Meister,
Are these the one's you had reworked? If so, how are they doing? Phil |
Yep, John reground that set. I have not checked it over in detail, but I do peek at whatever cam lobes are visible at the annual valve adjustment, and I have not found anything. Mileage on the set is probably 20-25K. A decent amount of track use initially, though only a 2 day weekend in the last 2 years.
Thanks Henry, good to know, thanks for sharing!
