Where to use JB Weld?
I have a '87 3.2.
Other than the back of my chain boxes, Where do I need to apply JB Weld?
Wayne's book mentions some areas, but it seems there are many other various plugs that look like they should be covered with JB Weld.
Also... is there a certain type of JB Weld I should be using?
Thanks all.
one step closer to rebuilding my engine.
1987 Porsche 911 Carrera Coupe
Old 06-21-2020, 05:44 AM
original jb weld,
Old 06-21-2020, 09:26 AM
Clean and reseal the oil gal lies behind the flywheel too
Bruce
Old 06-21-2020, 03:49 PM
Dont forget behind oil cooler
Old 06-21-2020, 04:11 PM
Originally Posted by Dpmulvan View Post
original jb weld,
So I went to pick up some 'original' JB Weld and was confused as there are apparently different versions of the 'original' JB Weld.
One product has a tensile strength of 3920 psi and another has a tensile strength of 5020 psi.
Which one is recommended on our engines???
Old 07-03-2020, 08:38 AM
Originally Posted by Trakrat View Post
I have a '87 3.2.
Thanks all.
Did you find a list of other places that need JB Weld?
Old 02-13-2024, 11:18 PM
It's a 914 ...
stownsen914's Avatar
Here is what I call original JB Weld. Looks like the 5020 psi stuff.
https://www.jbweld.com/product/j-b-weld-twin-tube
Old 02-14-2024, 04:18 AM
yes thats it. don't ever use the JB Kwik, its a total joke!
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 02-14-2024, 05:37 AM
All the ends of the oil galleys. Also the chain cases, on the back side, were the pins are pressed through the case. The factory did that as a preventative measure.
Old 02-14-2024, 06:41 AM
Jeff Alton's Avatar
The "orignial" is the best. But, we need to realize that it is a back up of sorts. We see many engines in car, and for rebuild (that have been previously apart) and see none of the areas sealed, and no leaks. The exception to this being the chain ramp pins in the timing boxes.
Cheers
www.turn3autosport.com
Old 02-14-2024, 10:26 PM
The spots I JB’ed.
Old 02-16-2024, 07:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
All pretty good information. We prefer the Loctite Hysol Epoxi-patch to JB Weld but either will work just fine.
We gluing the main galley plug near the fan ring, be sure that the glue doesn't encroach on the fan ring seating surface.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-18-2024, 07:00 AM
Very good point Henry. I’ll make a point on your comment. Thanks!
Old 02-18-2024, 05:55 PM
