how do you remove oil splash valves?
Hey guys,
how do you remove, and reinstall the oil splash (oil squirter) valve?
some good ideas? videos?
Cheers, mads
Old 07-04-2020, 02:32 PM
abit off center
cgarr's Avatar
use a 1/4" ball burr to cut the top off, go deep enough to remove the 3 stakes, pull the guts out, use a 5mm tap to go inside, heat up the outside alum and pull it out.
I use a bit of hard setting permatex on the valve, keep it away from the bottom, drive it in carefully with a 1/4" drift, stake it in place.
______________________
Craig
G2Performance
Old 07-06-2020, 03:30 AM
Here's a good thread on removing the squirters.
*&%$# piston squirters
Old 07-06-2020, 08:51 AM
Thanks for the advice / description Cgarr!
My tech english is not that sophisticated... But i hope i can get started (on a better note) with your advice!
I started the other day, armed with a YouTube video ... (in Spanish that I don't understand) and destroyed the first one ...
Old 07-07-2020, 07:50 AM
Hey HaroldMHedge. Don't know if I'm doing something wrong? But I can't open your link!
Old 07-07-2020, 07:54 AM
Here's the webpage link again. It should work this time.
Old 07-07-2020, 11:12 AM
Walt Fricke's Avatar
You do know that the piston squirters are always destroyed as part of the removal process?
Or did you destroy a new one putting it in?
Old 07-07-2020, 09:50 PM
Wow... That was the holy grail of info! Thanks HaroldMHedge
Old 07-08-2020, 06:46 AM
No. I drilled it out like in the video but I couldn't pull it out like they did .. so now it's stuck. But I'm on the case, thanks to your advice. (and a good machinist friend)
I buy new ones when I can measure it all out.
Old 07-08-2020, 07:25 AM
You should try some heat to release the squinters. Loctite 270, 620 and 640 require a temperature of 250C to break the bond.
Old 07-08-2020, 09:36 AM
