Setting cam timing with engine in car?
Hi guys.
I just finishing an efi install after many years but had a leak at the chain housing to cam tower. Changed gasket and ring with engine in situ which was a pita job and thought i`d left cam timing untouched. So now it won`t run properly and goes lean etc then dies.
So might have to open her up once more to time cam. Is this hard to do with engine in car?
Positive is that i stopped the leak
Thanks to any tips
Gone!
Old 07-16-2020, 08:19 AM
You have to remove all the muffler and metal off the rear of the motor including the motor mount
Disconnect electrical, fuel, oil and venting to lower the motor.
At this point, take the half shafts off and pull the motor, put it on the table, you’ll be much happier
Bruce
Old 07-16-2020, 09:54 AM
oof. I trust your judgement sir so i`ll do that. thx for chiming in.
so much work and it`s coming out, again.
Gone!
Old 07-16-2020, 10:21 AM
Turbo, lots more to come off...
Bruce
Old 07-16-2020, 06:10 PM
Check the cam timing first before you go to the effort of removing the engine
Old 07-16-2020, 08:50 PM
How do i do that? Guessing removing the valve cover and mount the dial then turn the engine like i would to see like i would anyway?
Gone!
Old 07-17-2020, 03:05 AM
Cam timing inspection........
If you could check your cam timing in situ, what’s the point of removing the engine? For cam timing work, I rather drop the motor and do the cam timing with motor installed in an engine stand.
Tony
Old 07-17-2020, 11:34 AM
Walt Fricke's Avatar
Checking the cam timing isn't any harder, really, with the engine in the car than with it on your engine stand. Of course you should do that before you do anything else. What is the overlap at the proper TDC for the cam you worked on?
I once did what you did - pulled the chain housing cover, removed the cam chain sprocket, found I had failed to tighten the three 10mm head bolts (hence big leak), tightened them, put everything back together as they were, and before putting the cover back on checked the timing. !it hadn't moved! I was astounded and elated. All in the closed trailer in a Walmart parking lot at Las Vegas before a race.
You had to go a little deeper, but I think nothing which would have moved the cam necessarily if the pin went back into the same holes?
Mind you, this was a race car, with a whole lot less to remove, and the bodywork cross piece behind the engine is removable as well, and not a turbo.
If you could do what you did with the engine in the car, you ought to be able to retime one cam if needed. No engine builder would want to do it that way, of course. You are the one to balance the pain of the one with the effort to remove the engine, put it on a stand, then remove more stuff, and reverse the process.
Hindsight - too bad you didn't check the cam timing as soon as you were done with the hard part, and before you started to put the cover and other stuff back on.
Post hoc ergo propter hoc doesn't always work, either. You won't know until you check the timing of that cam if it is out of whack enough to produce bad running (luckily it seems not so far out of whack as to lead to valves hitting pistons). You just installed EFI, and there are no end of things which can cause problems there.
For instance, the rebuilt injectors I bought didn't work (shop forgot a final lubrication step). In addition, the throttle position sensor, which should give a rising voltage signal as the throttle is opened, in fact gave a lower signal to begin with, and only at some point did what it was supposed to do! So if I could get the engine over maybe 1,500 or 2,000 RPM it would run OK. Just examples to suggest something else might be the cause.
Check.
But it might be off.
Old 07-17-2020, 02:47 PM
Tony
It’s no harder to check cam timing than adjusting valves. Just have to remove the intake cover and attach the dial indicator to the intake valve.
Old 07-17-2020, 10:03 PM
Yeah i also was thinking that. If i can change the chain box gasket and o-ring in situ i should`ve just done that while i was at it. Just wondered if anyone ever did this.
And ofcourse taking out the engine and put it on a stand makes it easier to time the cams but so is changing the plugs when the car is on a stand but i`m not taking out the engine again just to do one thing unless i have to. Off with all the wiring again, axles, oil mess and all the trouble jacking it up to get clearance etc etc. If i had a garage with fancy tools then maby
I`ll try in position first if i find the cam out of position. Thx for the input guys
Gone!
Old 07-18-2020, 05:09 AM
My work space
Gone!
Old 07-18-2020, 06:49 AM
There are days when I think fondly of my air cooled VW beetles. I could pull the engine with a couple of wrenches and the car's jack in my trailer home driveway: Disconnect all but the bolts to the tranny. Remove rear wheels, set car down on a bit of wood under the engine. Undo the 4 bolts and slide the engine back a bit. Jack the car back up and pull the engine out. 911s are more work in a lot of ways.
Several of us are waiting to see what that cam's timing measures.
Old 07-19-2020, 01:43 PM
... Just examples to suggest something else might be the cause..
Sorry to hear you’re contemplating having to go back in. Having just rebuilt and reinstalled mine last week, that would be a very tall order, mentally even more than physically. But as Walt suggested, you changed a ton of stuff. Perhaps the issue isn’t cam timing related. I’d pull the valve cover and verify cam timing on #1 or #4 whichever is easier and get some facts on the table. Good luck pal!
Ken
1986 930 2016 R1200RS
Old 07-19-2020, 07:06 PM
He only worked on one side/cam, so that's the timing he needs to check. Checking the other cam also might make sense, since it is really easy. But probably won't help the diagnosis.
Old 07-19-2020, 08:38 PM
Thx guys for encouraging me
2 of my freshly rebuilt calipers was also leaking badly so i had to tackle that also today but i was able to check timing and also discover a small oil leak through the intake valve cover gasket. I actually remember forgetting to put loctight on the valve cover itself, only on the head side. I also remember thinking this would be ok. NO!! So a redo
Hindsight WF is always annoying but i agree, i made so many mistakes with this build because of shortcuts. Lots more work because of it but i have held the costs down. Wish i could just ship it to TK.
Anywho,
Exhaust off
Dial on but i adjusted it a bit so it was straight.
Timing around 0,95 if i`m not mistaken
View post on imgur.com
And around 0,98
Before chain box gasket/o-ring change. High idle but running great. I WAS so happy
So is that far off enough to mess up cam trigger sync etc? Also, off with the turbo lower the engine just a little and i`ll time that fooker if needed in situ
Gone!
Old 07-20-2020, 09:41 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I adjusted cam timing with the engine in the car. Was no more difficult then with it on the engine stand. Was a 73 E so less stuff in the way than a more modern engine.
Old 07-22-2020, 08:59 AM
So the spare gasket i had laying around turned out to be wishful thinking. Had to do a parts run and finally my local Porsche Center had what i needed.
Love that Locktight 574 but it`s a mess too clean up when you use as much as i did. But it was perfectly leak free!
So set it to about 72. On the video i took it just over TDC.
I will ofcourse agree that this would be easier to do outside on a stand but it`s no problem at all doing it in car. Only hassle is the sheet metal bolts. So tight and frustrating. 8
Conclusion is that this is something you do when the car doing valves, gasket changes etc but if you just need to time a cam, not a biggie. If i can di it.......
Continues tomorrow with doing megasquirt again. Crossing fingers this was the issue i had!! Thanks guys!
Gone!
Old 07-22-2020, 09:27 AM
Good job getting in there and getting it done.
Good idea with the crank bolt access hole- they should have come like that.
Ken
Old 07-22-2020, 09:55 AM
Thx and congrats on your impressive build!
They absolutely should`ve yes. I must admit if this was a low mileage original collectors car i wouldn`t cut in it. It is not so out comes the angle grinder
Also if the $ keeps dropping in value compared to norwegian viking coin i`m drooling on the TKs GT30 or 35 turbos to replace my 7006 laggy beast.
Best thing about having a car you can work on is upgrading. Wonder how it is to drive
Gone!
Old 07-22-2020, 10:03 AM
Access makes it easier to perform some operations. I hope I don't have to go here for awhile.
S
Old 07-26-2020, 06:20 PM
