Earthling
Brian Cameron's Avatar
Torque value with plus sign?
What does it signify if a torque value looks like this: 50 + 5 ?
not 50+/-5 degrees (unless it shorthand for the latter, but i doubt an angle gauge would make sense in this application).
Does it mean tighten to 50 Nm, then add 5 more (for total 55) and re-tighten?
or what????
TIA
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 08-13-2020, 06:23 PM
JoeMag's Avatar
I’ve only seen those on drain plugs... I’ve always assumed they meant 50 and if it leaks go to 55.
Never had a drain plug leak with seal ring.
Old 08-15-2020, 02:55 PM
Earthling
This is from a ZF manual for power steering rack rebuild - both notations are used. Some of them would be pretty hard to get at if they leaked after reassembly
Old 08-16-2020, 08:40 AM
al lkosmal's Avatar
This is a guess, but I would say that those are tolerances......of 50+5...I.E. +5/-0 spec, resulting in a torque value of 50-55 (although I can't say I've seen them expressed quite that way before)
However, some of the other specs, like the tie rod show typical +/- tolerances of 80 +/-8 giving you a spec value of 72-88.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 08-18-2020, 03:59 PM
