Registered User 4'10
Cool MFI ball joint - lube?
Hi guys,
I've searched the forums but can't find it. My question is: should I lubricate, or not, the ball sockets on the ends of the push rods going to the throttle bodies in my '69 911E? If so, with what?
thanks, cheers, jt
jt - '69 911E, PCA-RMR '75-'82; Current Other: '16 BMW 328i, '18 Subaru Forester, '09 Kawi Concours 14, '85 VW Westfalia, C172, C152; Previous Notables: '89 Goldwing (RIP), '80 Suzuki 850, '64 Ducati 250, '64 Bug (wish I'd known about that #3 exhaust valve...), '59 Austin-Healey BN100-6, '59 Impala 2-door hard-top (cool!). '49 Cushman motor scooter, Grumman AA5A & AA5B
Old 07-27-2020, 06:53 PM
Yes ! they need lubrication . i like a mixture of grease and anti- seize compound , but anything is better than nothing .
Old 07-27-2020, 10:05 PM
Thanks Richey, And I finally found a way, last nite, to search the forum using multiple words to narrow the search. Then I found others saying they grease them also. Now I'm debating btwn Molybium (lithium base), and just white lithium. I imagine it's not a biggie which. Thougnts?
Thanks, cheers, jt
Old 07-28-2020, 09:45 AM
High temp grease for those ball joint linkage old school original.. gets tight in the winter
.. but a small dab of ATF work best now in all weather conditions
Old 07-28-2020, 10:31 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
anything will work. prob lithium grease, but what ever is handy.
Chris
73 E
Old 08-06-2020, 01:43 PM
Thanks guys. I decided on white lithium. Added benifit is you can then see if you've got any in the sockets.
cheers,
jt
BTW: I'm happy to report that after 5 years of woriking on a complete engine rebuild, working off & on, I bolted the last pieces (air stacks) on her yesterday! Now all I've got to do is get the car ready to install the engine (gas tank & lines, brakes, transmission, .... )
Old 08-09-2020, 09:37 AM
Jeff Alton's Avatar
We use a Liquimoly ceramic paste, sadly not commercially available. Our rep brings it in as samples for us from Germany. That said, any good lube that will stay in place and not dry out like anti seize would work well.
Cheers
www.turn3autosport.com
Old 08-18-2020, 09:08 PM
