JoeMag's Avatar
How do I get the lower fan pulley off (6 rib)
There are larger diameter threads that the bolt that holds to flywheel goes through, so wondering if I just screw a bolt into that it'll push off?
..don't mind the pink dots, i use to first pass install degree wheel.
Old 10-04-2020, 07:00 AM
Walt Fricke's Avatar
What does Clewett say?
Old 10-27-2020, 03:54 PM
Racer
winders's Avatar
Heat it up.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-27-2020, 04:48 PM
There is a special tool that screws into the larger threads and has pointed end for the crank side
Made out of softer metal to not mess up anything you can buy them from like baum tools not
To expensive
Old 10-27-2020, 06:01 PM
JoeMag's Avatar
Thanks... figured out “push off threads” Are 16mm fine so I just got bolt that fits and I’ll cut piece of brass punch to put in front of bolt and use that to push on crank.
Old 10-27-2020, 06:08 PM
